My 100,000 mile Pre Denver Bound Service
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by frodoz737, Oct 9, 2015.
  1. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    Just finished thorough inspection, oil/ filter change, ATF drain and fill, engine and inverter coolants changed, brake flush-clean-adjust-lube and F/R pads (rotors are good), new 12 VDC battery, spark plugs, struts/shocks/isolators, rotate-balance-alignment, engine and cabin filters, F/R wipers and updated Kenwood/Garmin software. It's what we call a "C-Check" in my business. Picking up snow tires/steel wheels/front chains c/o Tire Rack Denver warehouse when I get there next week in readiness for winter.
    Anyways...car is handled until next 5,000 mile oil/filter and tire rotation.
    #1 frodoz737, Oct 9, 2015
  2. Mendel Leisk
    40,584
    Did you go with the stock battery? Just curious.
  3. frodoz737
    4,535
    2,438
    33
    Yep...and I got a real good price too with no core...;) This was a time change. The old battery still has life and being kept for just in case s--t.
  4. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    nice work!
    Moving to Denver, eh?
    Unless you're in the Mountains, you probably won't need chains. Sun melts the snow within hours along the front range/denver proper.
    it does, however, turn to ICE the second the sun goes down for the day!
    My other car is a Subaru.....they're king out here (for a reason......never have I had that car get stuck, and I have been trying every year since purchasing it new in '05).
    anyway - welcome to Denver. Look out for all the crazy drivers!
    dorunron likes this.
  5. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Funny how in different places folks warn you about "crazy" drivers...
    mmmodem likes this.
  6. frodoz737
    4,535
    2,438
    33
    Thanks, rolling in Wednesday. Chains is just being prepared like a shovel, brush, scraper, alcohol solution, snacks, water...you know the drill. As far as crazy drivers go...that's a given everywhere.
  7. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    You won't need chains. If the snow's that bad, your low sitting Prius won't get through it anyway.
  8. frodoz737
    4,535
    2,438
    33
    Thanks. While your posted location implies you might know better than myself as it pertains, chains will be on-board. I have a special tool in my box that has only been used maybe a dozen times in my career, but when I need it...I really need it. ;)
  9. Jimi1976
    242
    124
    Denver, CO
    crazy drivers.....it's weird here. I've lived in LOS ANGELES, CHICAGO, driven coast to coast....and the drivers here are the worst. It's because so many people are moving here, from all over the country (keeping the landlords and real estate agents filthy rich......).
    Slow (stoned)....fast (drunk)...blowing red lights (Californians).....I've never had to be a more defensive driver in my entire life.
    And yes - chains good for above 7K.
  10. frodoz737
    4,535
    2,438
    33
    Not to side track my own thread, but the biggest problem I encountered relocating to Denver was finding a room for rent. Oh they're out there, but Colorado's new 4/20 friendly law "extremely" limited my search. I was successful however finding a place where they don't partake or tolerate.
  11. frodoz737
    4,535
    2,438
    33
    I'm here...yea!
  12. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    I Love Snow
    :D
    frodoz737 likes this.
  13. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I would never have thought of that. Good for you and congrats on getting there. I assume you didn't need the snow chains. :)
  14. frodoz737
    4,535
    2,438
    33
    Thanks!
    :LOL: fotomoto. Tires/wheels being ordered next week...still getting a set of chains just in case. ;)
  15. frodoz737
    4,535
    2,438
    33
  16. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    If you plan on driving around Colorado, you can easily get caught in a freak snow storm where you might need chains to get back home. In late 1970, I left Denver for Phoenix when it had just started to snow. They let us out of class early and little did I know I was on the leading edge of a major storm coming from the south. By the time I got to Trinidad, it was so bad I tried to find some chains. Having no luck, I reluctantly pressed on. At one point going up Raton Pass, a semi jackknifed and I had to stop on a hill. When it was clear, I couldn't get up the hill, so I had to back down to get a running start. Fortunately I was the only car behind the semi. I made it over the Pass just as the radio said they were closing I-25 on both sides of the Pass. I was driving down the middle of the freeway because I couldn't see the road and only had the raised shoulders to guide me. As it turned out, I was the only one from my class to make it out of Denver that day, airports were closed right after I left, etc. Once I got over the Pass, it cleared up and the roads cleared. I guess the storm had actually started right at the Pass and headed north. I had kept up with the storm's progress on the radio, so I knew I'd be clear if I could make it over the Pass. That was then, today I'd stay in Denver and try another day. :)
  17. Mendel Leisk
    40,584
    Amen!
  18. frodoz737
    4,535
    2,438
    33
    Yea but some of us have to drive and work in it.
  19. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Between the two, I like Discount Tire, both stores I've used have been great to deal with.
  20. orenji
    orenji Senior Member
    5,886
    3,487
    Make sure you flush the bottom of the car and wheel wells weekly to get off all the road salt, so you car does not look like this!!
