My 2005 Prius is dead. How do I diagnose the problem?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by b_o_og, Nov 29, 2018.
  1. b_o_og
    b_o_og New Member
    Anaheim
    My 2005 Prius is dead. The most I can get out of it is an intermittent red light on the power button on the dash. The scanner does not get enough power to get a read. I bought a new auxiliary 12v battery from the dealer to no avail. Any thoughts?
  2. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Check the voltage at the jump points under the hood. You could have a bad battery cable.
    49,704
    check the battery connections as well, especially negative to ground. and even though the battery is new, it might be defective, or just need a charge.
  4. ChapmanF
    15,872
    ... and if checking there doesn't find you the problem, just move your meter around and check other spots. The power-distribution section in the wiring diagram will help you pick good spots. In the diagram, you'll also spot which fuses might be likely suspects, and could be partitioning the distribution tree into branches that have power and branches that don't. Weird behaviors ensue.
    -Chap
    Skibob likes this.
