My 2010 PowerPoint Presentation
Discussion in 'Gen 3 Prius Main Forum' started by Patrick Wong, Feb 7, 2009.
  1. Patrick Wong
    17,885
    5,840
    I will be making a presentation to the OC Prius Club this afternoon and compiled the following PowerPoint file, converted to .pdf. My interest is mostly the drivetrain, so that is where the presentation's focus is. I'm sharing the draft with the group because we now have ~150 people who have seen and studied the 2010 in Detroit, DC, and NYC.
    I am also going to have the Media Information DVD with the official Toyota photos in case anyone wants to see detail not shown in the photos embedded in the presentation.
    If anyone sees glaring errors or has ideas where to get 2010 physical dimensions not shown in the presentation, pls reply.
    Thanks!
  2. carz89
    carz89 I study nuclear science...
    444
    46
    San Diego
    nice powerpoint!
    but I think there are a few errors you may want to correct before your presentation:
    "smaller traction battery size" -- I've read many times here at PC that the traction battery is the same size, but some of the cooling and control components are either smaller or packaged better to save space.
    your net HP numbers ... you say that the battery provides HP. Most of us know what you mean, but I think it's more accurate to say MG (1 or 2?) horsepower. Also, are your numbers right? I don't think you can do simple addition with the ICE and MG horsepower numbers to get 134 HP total.
    Under "Options" slide - you didn't finish your sentence "remote AC on" [the keyfob].
  3. efusco
    efusco Moderator Emeritus
    19,882
    1,153
    Nixa, MO
  4. patsparks
    10,664
    562
    Adelaide South Australia
    It's a great job.
    Actually I think Patrick meant "remote-on AC." As in, you can remotely turn on the AC. (no ability to remotely turn it off.)
    More compact battery configuration?
    Oh the electric motors are smaller and lighter.
    I see question marks for internal dimensions, why not state 5? cubic feet more interior space with little change to external dimensions.
    Added rear head room through a more rearward roof peak.
    duel grab handles to lower hatch.
    Aero-corners? Might rate a mention?
    Sharp edges on rear for smoother air flow off the vehicle
    Vanes on rear under-tray for added stability.
    Do 4 wheel disc brakes rate a mention?
    I hope this helps.
  5. Tideland Prius
    10,992
    40
    2018 Prius Prime
    Technology
    Actually, you do have the ability to turn off the A/C remotely using the same A/C button on the fob.
    ON: Press and Hold A/C for more than 2 secs until you hear the beep
    OFF: Press the A/C button twice.
  6. Patrick Wong
    17,885
    5,840
    Thanks to all for your prompt review! (Pat, isn't this past your bedtime??)
    The ICE and traction battery hp ratings come from the Toyota Prius website. 2009 hp numbers are not additive while 2010 numbers seem to be.
    I added four-wheel disc brakes and clarified that the traction battery has a smaller physical size but greater rated power.
    I edited the point about the remote on/off AC.
    Although I've seen the claim about smaller motor-generators, since I can't see them in the drivetrain model and the transaxle still looks around the same size, I did not include that claim in my presentation.
    Regarding interior dimensions, since I can't verify the claim of 5 cu ft increased space, I will not include that. However I eventually hope to compare the various dimension categories once they are published for 2010.
    Evan, thanks for the offer to use your beautiful and very sharp photos. If I have a future opportunity to present I will use your photos (and include a footnote giving you credit.)
    Attached is the final presentation for today.
  7. patsparks
    10,664
    562
    Thanks, I didn't know that. I can go to bed now, I have to learn something new every day. I had to wait till 4.30AM for that.
    Patrick, yes it is but I'm not tired.
    I forget where I saw smaller motors. And the 5 cu ft extra space but I know I saw it.
  8. sdtundra
    sdtundra Senior Member
    1,315
    196
    Sacramento, CA
    Man, I wish I could have gone. I was originally going but work came up and how fun I get to be at work on a Saturday.
  9. Patrick Wong
    17,885
    5,840
    No worries, in this slow economy your work needs to take first priority.
    If you have any Qs about my presentation feel free to raise them in this string or in a private msg, whatever you prefer.
  10. patsparks
    10,664
    562
    I should have reposted, edited my last post.
Loading...
