My 2010 Prius is officially an oil-burner
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by southjerseycraig, Sep 14, 2017.
  1. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    That's why my Toyota dealership told me today. The car is burning between half a quart and a quart of oil every thousand miles. The car has 92,000 miles on it. I've driven a couple of past cars over 100,000 miles and have never had this problem. I will have to think long and hard before buying another Toyota vehicle.
    amos likes this.
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Unfortunately the 2010 is notorious for burning oil for many owners. I'm sorry for your (oil) loss. :(
    danlatu likes this.
    49,507
    read up in the oil burning threads, there might be some things you can do to alleviate the problem.
    Raytheeagle likes this.
  4. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Thanks! I have the impression that it's not just the 2010 -- that later Generation 3 models have the same problem. It is of course seen first in the 2010 because it's the oldest, and so has the most high-mileage vehicles.
    milkman44 and m.wynn like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Knowledge is power;).
    With your new understanding of your Prius, keep an eye on the dipstick and top up as needed.
    Our 2010 Prius II with 163 k miles is still going strong and I found it burning a quart of oil every 4500 miles at 120 k miles. Have done some things to get the oil burn down to less than a quart between 10 k mile oil change intervals :).
    Some things to consider to help your situation out:
    • Use 5w-30 full synthetic oil
    • If you travel highways much, keep you speed 0-5 mph above the posted limit
    There are more things that you could do, but I would start there;).
    Keep us posted (y).
  6. Mendel Leisk
    38,736
    Never slower? I know, just had to ask, lol.
    Regarding the assertion that it's just 2010: yeah I don't see that, but not sure.
    Could be the PCV dumping oil into the intake, which combusts and returns once again, a little more toasted, via the EGR, coking up piston rings, clogging EGR, raising temps, and so on
    danlatu, mjoo, bisco and 2 others like this.
  7. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    I have a feeling if the OP were to go slightly under the posted highway speed limits that he would feel the "brotherly love" of the surrounding metropolitan area ;).
    I agree that the 2010 is painted in this light, but we have other model years suffering the same fate within the Gen3s. One factor might be the shear number of them, given the long production run. Also they are the oldest, so the components are the oldest. As things age, they don't always perform the same:whistle:.
    But oil burn can start a viscous cycle, so best to beware (y).
  8. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Thanks for the responses. I tend not to drive that fast anyway and will try not to exceed the speed limit by more than 5 mph (except on the expressways that have 55 mph limits because they're in urbanized areas; try to go only 60 mph and you'll be an obstruction to traffic.)
    Why would using full-synthetic oil work better?
    Is it unfair of me to expect that a car with 90K not burn oil?
  9. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Your Prius was given 0w-20 full synthetic oil from the start, I'm suggesting going up in weight, which is something commonly done when oil burn is seen and not a puddle underneath where you park.
    While it is fair to expect that at 90k miles you shouldn't see oil burn, the unfortunate truth now in your situation is you are:(. But frequent monitoring will help ensure the problem doesn't get worse;). If you keep an eye on the dipstick and add oil as needed, you'll still get plenty of life out of your Prius.
    Hope that helps (y).
    milkman44 and mjoo like this.
  10. Mendel Leisk
    38,736
    We've had a slew of Hondas over the years, and as best as I can recall all of them burned a little oil. I never thought it abnormal.
    But it was relatively minor, maybe a cup top-up between oil changes when new, 2~3 cups as they accumulated miles. Never heavy, quart after quart consumption.
    danlatu and Raytheeagle like this.
  11. eman08
    eman08 Active Member
    360
    192
    US
    I have 179,655 miles on my 2009 that's runs like a top. I burn about 1 quarter roughly ever 1,500 to 1,600 miles. Every time I change my oil, I usually buy the 5 quart jug and save the remaining left over to top off in between oil changes.
  12. bisco
    49,507
    yeah, gen 2 wasn't nearly as bad.
  13. jadziasman
    1,355
    487
    District 6
    a quarter of a quart? o_O
  14. eman08
    360
    192
    US
    Raytheeagle and Prodigyplace like this.
  15. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Would you guys forgive a really stupid question? As I understand it, one uses a funnel to put oil in the car. How does one prevent oneself from overfilling -- which I gather is as bad as underfilling?
  16. Mendel Leisk
    38,736
    The distance between the two marks on the dipstick is around 1.6 quarts (1.5 liters). It's also about 1.5 inches. So you can do the math from there. A lot of oil bottles have a clear strip down the side with measurement markings too. And if you're really nuts (I am), you can get a graduated pitcher. Don't use one from the kitchen, lol.
    Simplest too: just pour a shot, give it a moment, then check the dipstick, repeat as needed.
    #16 Mendel Leisk, Sep 16, 2017
    southjerseycraig and Raytheeagle like this.
  17. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    If you do pull one from the kitchen, don't take it back in;).
    I pulled and replaced :).
    Sometimes good to know how much you are adding (y).
  18. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I'll be curious to see as years pass if this oil burning issue starts to manifest in later model years, 2011, 2012, 2013....
    Did Toyota ever admit to an engine design change between 2010 and any later Gen 3 model years? As far as I know, they are the same engines.
  19. southjerseycraig
    438
    107
    Cherry Hill, NJ
    I think that if you check the forums for Prius 3's, you will see people complaining about oil burning in post-2010 3's.
  20. bisco
    49,507
    eleven's for sure.
