My 2012 Prius V. Clear coat is shedding off. Like a sunburn.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Dpestes, Dec 11, 2024.
  1. Dpestes
    Dpestes Junior Member
    Anyone have this issue? The clearcoat is shedding or like when you get a sun burn how the skins peals.
    Also car squeaks when I stop and accelerates also getting out of the car. It’s so annoying. My boyfriend says he can help it. There is no place to grease or put lube. Like in my old Camaro I had a grease gun and there were fitting to put grease in.
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,566
    5,875
    Texas Hill Country
    Clear coat typically comes off the plastic spoilers in the rear. Usually caused by cheap car wash's roller brushes over a period of time. Not much can be done aside from a respray, perhaps from a discount place like Maaco.
    Squeaks are usually from the front suspension which can't be greased. Sway bar links or struts are common squeak points.
    #2 rjparker, Dec 13, 2024
    BiomedO1 likes this.
  3. Air_Boss
    Air_Boss Senior Member
    4,136
    1,152
    New Yawk
    No clear coat, but the finish on the top flip surface of my rear spoiler is just becoming dull. The rest of the car is still brilliant Winter Grey Metallic.
  4. BiomedO1
    BiomedO1 Senior Member
    2,780
    1,477
    SacTown, Ca
    That's what happens when a car sits in the sun and doesn't get regular cleaning and waxing. Yes, those mechanical car wash brushes will do a number on your paint, but also those high pressure water guns too. If you can find a shop willing to just respray the clear coat is the only way to take care of that.
    You can spray WD40 or rubber restorer on the suspension grommets should temporary relieve the squeak.
  5. Brabus82
    Brabus82 Junior Member
    Taylors, SC
    2015 Prius v wagon
    I have 201k on my 2015 and the clear coat is still good. It's lived outside all it's life too. The hood is full of rock chips but that's another story ...
