My 2016 Prius 3 having trouble with emissions test in Tennessee
Discussion in 'Gen 3 Prius Main Forum' started by janie, Nov 4, 2021.
  1. janie
    janie 2016 Prius 3 Touring
    175
    42
    Three Touring
    My 2016 Prius 3 won't pass the emissions testing in Tennessee, originally purchased in California and now I live in Tennessee and last year and this year they say my Prius won't communicate with their test equipment- the technician says my gas motor won't stay on long enough -
    I don't want to pay toyota 230 dollars to trouble shoot -
    Do you think if I put my air conditioner on high that it might keep the gas motor running?
    Thanks so much!
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,572
    5,878
    Texas Hill Country
    Maintenance Mode to Continuously Idle Engine
    Press Start button 2 times
    Press Gas Pedal 2 times
    Press brake and shift to Neutral
    Press Park
    Press Gas Pedal 2 times (hybrid warning light will start flashing)
    Press Brake and Start button (starts engine, don't drive it, shutdown to return to normal)
    #2 rjparker, Nov 4, 2021
    Michael Wood likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    I think you need to have the test done at an actual Toyota dealership.........where they will hopefully know how to do the test right.
    Is the test mandatory where you live ?
    I didn't think Tennessee did that.
  4. janie
    175
    42
    Three Touring
    Thanks- yah, they require it in the county i am living in= but here's a caveat-
    * I have a new rav4 hybrid that is in transit (was/is due to arrive in early November)
    * The county i am living in will stop the mandatory annual emissions testing in January
    So, I can hang tight and see if my new car will arrive in time before I need to update my current tags which technically
    I got last year Nov 12th . . .
    and RJ Parker thanks for the instructions-
    I will copy it so I have it in my notes on my phone and know what to do when my car is parked
    for the emissions test-
  5. bisco
    51,120
    usually, the engine does not need to run. have you tried different inspection stations?
  6. BZzap!
    BZzap! Senior Member
    1,607
    878
    Yep, go to someone who knows what they’re doing.
  7. janie
    175
    42
    Three Touring
    Thanks- there is only one emissions testing center in my city= and they are all connected and the same main guy oversees all of the places in the county- but the good news is i found out my registration is good through the end of this month and since my new car is supposed to arrive in early November - i shouldn't have to get my car retested-
    also, a new friend/couple here in Tennessee they have a prius, says they have had that same emissions center test their prius and it has passed easily . . .
