My 2017 Prius has active cruise radar, but no blind spot protection. Can I add this feature?
Discussion in 'Gen 4 Prius Main Forum' started by Jerry LaBant, Sep 4, 2020.
  1. Jerry LaBant
    Jerry LaBant Junior Member
    Liverpool, PA
    Friends,
    I’ve just traded my 2007 Prius with 427,000 miles for a 2017 with only 46K on the clock. While this new generation is fantastic with all the new technology, it does lack the “Blind spot” detection feature. This car is equipped with the front cruise radar and The automatic braking Technology, can I ad the bind spot technology to this car? Could I be lucky enough to find that it’s just “plug-n-play” with new mirrors that have the sensors?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    My suspicion - NO.
    Only way to get it is to trade it on a car which has it.
  3. Tyfly
    Tyfly Member
    65
    94
    I’m not sure there’s a way to add it. The blind spot monitoring is a feature I miss from my previous vehicle. Mine is a 2017 and if I had waited for the 2017.5 it would’ve been standard.
    The passenger-side blind spot is bad on this car, especially around the “C” pillar. Make sure you adjust the mirror far out to cover that side. It has helped me.
    Rggaebssplyr and alanclarkeau like this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Mine too.
    But I find the feature pretty much useless without a tiny audible beep to go along with it.
    But THAT would be a real pain on the freeway in heavy traffic too.
    So I am not sorry that mine doesn't have it.
    My Ford does and does not help me at all.
  5. fotomoto
    fotomoto Senior Member
    5,633
    3,808
    So. Texas
    Anything is possible with enough $$$ thrown at the problem but it would probably be very expensive unless you DIY with used parts; it might even be cheaper to find another one that has all the features you want.
    I specifically looked for a used 2018 level II because it had this (BSM) and all other other current (at the time) safety features included as standard. Living in the land of HUGE trucks and suvs, I also particularly like the rear cross traffic feature when attempting to back out of a parking spot.
    Old school: Look into the add-on convex mirror solutions. My C-Max has similar built in and they work VERY well.
    Also, I've found these electronic rear view mirrors work very well in showing the blind spots if the camera has a very wide angle of view (170 degrees). You can see in the electronic mirror vehicles on each of the car all the way up to almost the B pillar (that's the one between the front/rear doors). No kidding. These also include front/rear "dash cams" adding more features to the vehicle.
    #5 fotomoto, Sep 4, 2020
    Rggaebssplyr likes this.
  6. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    The actual BSM sensors are in the rear quarter panels (one each side) the mirrors only have the indicators.
    I had to replace a sensor on mine as it was damaged in a parking lot accident - it cost about $1,000. Also it can only be accessed by removing the rear bumper and quarter panel a very extensive job.
    It is extremely unlikely that your car has them already installed.
    As others have commented the blind spot monitor monitors do not have an audible alert and I don't find them anywhere as useful as the ones, for example, on my Mazda 3 that did have the audible alert.
    kevin
  7. sam spade 2
    7,035
    2,801
    2017 Prius c
    Didn't that get a bit annoying if there was a constant stream of traffic slowly overtaking you in an adjacent lane ??
  8. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Jerry,
    There are third party systems that cost from $100 to $300 such as:
    Jeffd
  9. kevinwhite
    333
    200
    Los Gatos Ca
    No, the audible alert is only given if the direction indicators are active such that the car in the blind spot is a real hazard. There were very few false alarms.
    My Tesla also only gives an audible alert if the indicators are on.
    I thought of adding an alert to the Prius but haven't got round to it yet. The various signals that are needed are available in the wiring harness.
    kevin
  10. sam spade 2
    7,035
    2,801
    2017 Prius c
    Well DUH ! (y)
    Good engineering.
    But that would be useless to about half of the drivers out there who don't use the signals.:mad:
  11. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    ...and the other half that don't use their mirrors!!!!
  12. Prodigyplace
    12,470
    11,724
    Central Virginia
    Nope. You have an early 2017 like mine. The BSM was added mid year. I really wanted that too but it is still a great car.
    Tyfly likes this.
  13. alanclarkeau
    7,045
    7,592
    The outer part of the mirror is even more convex than the rest of the mirror - maybe adjust the position of the mirror so this helps more?
    fotomoto and Tyfly like this.
  14. sam spade 2
    7,035
    2,801
    2017 Prius c
    OR....maybe STAY in your fricking lane unless there is an actual NEED to change.
    Seeing a gap in a lane next to you does NOT constitute a NEED to fill that hole.
    :mad::mad::mad:
  15. RRxing
    RRxing Senior Member
    2,540
    1,815
    NEPA
