My AC just turns on Automaticly
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fishcrab, Apr 26, 2015.
  1. Fishcrab
    Fishcrab Member
    152
    29
    With my ac/ heating system set in the off position, my ac comes on all on its on with fan .
    This happens after I have been driving for awhile. Is this normal?
  2. JC91006
    16,827
    8,600
    Your climate controls shows everything off and air is blowing from your front vents? When stopped?
  3. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Turning off the AC via the MFD just turns off the AC compressor. The Fan/Heat/Defrost still functions when the thermostat requires it. You can also turn everything off via the steering wheel controls.
    JeffD
  4. Mendel Leisk
    41,889
    Toyota refers to the whole system as "air conditioning" (at least in 3rd gen Owners Manual), which is frustrating/confusing. Maybe OP can clarify, is it the cabin ventilation system's fan, or the air conditioning (ie Freon compressor, and so on) that's turning on.
  5. Fishcrab
    Fishcrab Member
    152
    29
    It's both the fan and the ac compressor turning on. The yellow ac light come on,on display.
    Yep, I think they refer to in The gen 2 as the whole system being ac too.
    Prior to the ac coming on, the ac system is in the off position.
  6. bisco
    52,373
    what is your thermostat set at?
  7. Fishcrab
    Fishcrab Member
    152
    29
    It been around 77, usually not a really hot day.
    So are you saying if the thermostat is set low , the ac will come on? Even when unit is in off position.
  8. bisco
    52,373
    i'm not really sure, but what i am sure of is, the prius a/c seems to have a mind of its own sometimes:cool:
  9. bisco
    52,373
    could you be unknowingly hitting the steering wheel button? i have done that while holding a coffee cup.
    Dino33ca likes this.
  10. Fishcrab
    Fishcrab Member
    152
    29
    That's a good point Bisco, might be my wild driving.
  11. bisco
    52,373
    yeah, me too!:p every time i'd hit a steering wheel button by mistake, i'd be looking around for what caused the beep.o_O
  12. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    More likely it is a combination of the car's design and the very HIGH humidity if Florida much of the time.
    The fan never really shuts off completely; there is always a tiny air flow for safety reasons.
    I think that many recent models also never really turn of the auto climate control completely and will run the compressor at a low level to de-humidify the cabin when necessary. That is most likely to happen early in the mornings when the temps are down a bit but the humidity is up near 100%.
    This is my wild guess.
  13. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    There are within Techstream various options for how the AC is controlled in the same way that seat belt and reverse warnings can be turned off.
    John (Britprius)
    Fishcrab likes this.
  14. Fishcrab
    Fishcrab Member
    152
    29
    That's good to know, will look into it.
    I did stop beeper for backup, what a relief, for a long driveway .
