My best tank ever...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jimbo69ny, Jul 24, 2013.
  1. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    I'm sure there are those of you out there who have beaten these numbers but this is my best tank ever after owning this car for a year now.
    I drove probably about as far as I could have. It was on 0 miles to go for about a mile. I charge my car anytime its parked but unfortunately due to the area I'm in, hills everywhere, I cannot make a trip without the engine turning on to at least warm up. Most of my trips would be less than 15 miles round trip but Ithaca is a very hilly area. I really could've gone longer but because of the hills the ICE kicks on and uses up fuel even though I have enough electric to get home. Simply, I no longer had gas for the ICE to warm up with on each trip.
    Here are my results.
    1237.4 miles
    146 mpg (was 147 until the ICE activated on my trip home)
    0 Miles to go.
    usbseawolf2000 likes this.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    That's a great accomplishment. 1,237 miles on a 10.6 gallon tank.
    Did it last you a month or so?
  3. Jimbo69ny
    712
    107
    Ithaca, NY
    I dont remember the last time I filled up. (a plus of owning a PIP) But it had to have been at least a month ago.
  4. Jimbo69ny
    712
    107
    Ithaca, NY
    Its a completely different story compared to my 04 Tundra I had previously. I was spending $100/week on fuel! I bought an 08 Prius, parked the truck, and still ended up ahead. I even did great when I traded them both in on the PIP. Things have worked out nicely.
    Although I wish I had a car that could do 20+ miles on all electric and handle the hills of Ithaca. I wish I had a Volt for the range but a PIP for the cargo space.
  5. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    What's your overall EV ratio? Have the lifetime EV Ratio screenshot? It has kWh and Gallons along with EV/HV miles.
  6. bisco
    49,371
    well done jimbo!(y) is it hilly where you are?:p
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    good job! and 1 month! took me 6 to get anywhere near that amount:cool:
  8. retired4999
    2,652
    625
    Eau Claire, Wi.
    Nice Job! Jimbo, Well done!
    Hills are really a killer.
  9. Jimbo69ny
    712
    107
    Ithaca, NY
    I am at 45 ev 55 gas
  10. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    That is truly an amazing tank. I don't think I've gone that far as of yet. I think my max one month was 130 mpg excluding electric usage.
    I usually fill up within 30 miles of the light flashing ~9 gals to fill the tank.
    iPad ? HD
  11. lensovet
    2,614
    496
    Burlington, NJ
    i'm a little confused about your hills comment. is your ICE kicking on when going downhill or uphill?
  12. Jimbo69ny
    712
    107
    Ithaca, NY
    It does both. If I have a near full charge and I'm going downhill it will kick on so the batteries don't over charge. I try to put it in neutral before it turns on though.
    Going up it turns on almost every time.
  13. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Good job, Jimbo! I do too much freeway driving (EV/HV ratio 29/71% most of the time) so my tank usually lasts for 600-700 miles. I did have one tank on which I drove 1025 miles, but that was really unusual.
  14. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    I just got my best tank since i bought the PiP last august...so after a year this last tank has been best.
    It lasted me 65 days.
    I got 1538 miles from this tank. I always reset my EV1 Ratio at each fillup...
    Also getting 15.5 EV estimated range now in morning after full charge. My lifetime is now 107mpg.
  15. markabele
    5,084
    1,782
    Nebraska
    Don't really get this....
    Are you starting at the bottom of large hills stopped then must get up to 60 mph in a short amount of time? If not, then your engine doesn't "need" to come on...you are choosing for it to come on.
    lensovet likes this.
  16. lensovet
    2,614
    496
    Burlington, NJ
    Just wanted to make sure you were aware of the neutral trick! Definitely use that.
  17. Jimbo69ny
    712
    107
    Ithaca, NY
    By neutral trick to you mean putting the car in neutral and going down a hill? Yes I do that, hence the reason I said I put it in neutral. haha In neutral the gas engine wont turn on even if you go above 62 mph.
  18. Jimbo69ny
    712
    107
    Ithaca, NY
    I assure you I am not choosing to turn the ice on. It just does. Im not sure why it happens but I think it has something to do with the inverter. I could have plenty of ev range left but just as I get to the steepest part the power bar will move quicker to the right even if I am not pressing the accelerator any harder. The car forces itself into hybrid mode. I assume this is because the inverter heats up and cannot deliver enough power to get up the hill so it tries forcing the driver to use the ICE. If I go 45mpg up the hill I can make it but its a highway with a 55mph speed limit. People get PISSED when I go slow up the hill!
  19. Jimbo69ny
    712
    107
    Ithaca, NY
    How do you reset the EV/HV ratio? I thought you could only do this by disconnecting the battery.
  20. markabele
    5,084
    1,782
    Nebraska
    Are you in ECO mode? And is there a lane for people to pass you?
    Just press and hold the trip button while on the ratio screen and it will reset.
