My biggest gripe, after a year of driving....
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mikenancy1, Sep 26, 2013.
  1. mikenancy1
    mikenancy1 2012 PiP (Base), '10 Highlander Hybrid, '05 Prius
    105
    Geneva, IL
    ...when I plug in my iPhone to charge, either from the USB port in the center console or from the "cigarette outlet" on the floor, I get tremendous static on the FM radio. Never had that problem with my 2005 Prius. Anyone have a work-around?
  2. SLOW_RR
    SLOW_RR Member
    155
    84
    Finger Lakes Region of NYS
    My solution is twofold. 1. I don't listen to the radio, and 2. I don't have an iPhone....
    OK, I'll shut up and go away.... :whistle: :p :rolleyes:
    rogerv likes this.
  3. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    223
    Nature coast, Florida
    Three Touring
    First, I will start off by saying I hate Apple. With that said, are you using an actual Apple Supplied Charging Cord, or an after-market? If after-market, try the original Apple Cord. Also, do you have one of those battery jump packs on the phone? If so, it will increase the power draw and possibly cause your problem.
    If none of those apply, until Apple release an iCar, you may be out of luck...
  4. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    if that's the biggest, that's pretty good..
    you only get static noise or break up when tuned to a station? I have never experienced that.
  5. mikenancy1
    105
    Geneva, IL
    It only happens when I'm tuned into certain stations, but of course they are the ones I listen to the most. Except, of course, when I'm charging the phone ;-(
  6. Sfcyclist
    1,621
    375
    SF, CA
    sorry but I can relate.. never had the issue..
  7. Sfcyclist
    1,621
    375
    SF, CA
    oh and I'm actually fairly impressed by the stereo, non JBL, btw. Only minor gribe I have is poor reception and can't get a clear HD signal.. but I think it's where I live.
  8. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    Get a 12V->USB car charger and stop charging from the internal USB. You won't have the static, and your phone will charge faster.
  9. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    I had this problem exactly with my Gen II, and it occurred regardless of whether it was usb or usb via 12V outlet power. The static - or what was more like a low level buzz - was probably due to the analog connection (wired). The was very similar to "old fashioned" distributor feedback, that is, it ramped up as the RPM increased. However, I have not had any buzz or static problem with the PiP using BT or a wired (phono) connection.
  10. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I had the exact same problem. A strange hum noise. Turned out to be the cheap cable I was using. Get an oem Apple one.
    iPad ? HD
  11. Prius 2007 user
    Prius 2007 user Junior Member
    You're probably using a poorly designed charger. These things actually are small inverters, prone to generating high frequency interference. On proper designs those HF components are effectively filtered out. Try and get different ones on loan from friends or family and see if problem goes.
  12. Sfcyclist
    1,621
    375
    SF, CA
    lack of shielding and or RF noise from charger.. sounds highly probably.
  13. mikenancy1
    105
    Geneva, IL
    I never thought of that. I paid $5 for it, so I assumed it was top quality ;-)
  14. Sfcyclist
    1,621
    375
    SF, CA
    easy test.. unplug charger, use USB port with Apple cable and see if it goes away.
  15. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    $5.. Thats a cheapo one . And is the problem ...the Apple cost $19 to $29
  16. Sfcyclist
    1,621
    375
    SF, CA
    I use a usb cigarette charger from Monoprice that was like $4. It's works fine.
