my bittery
Discussion in 'Generation 1 Prius Discussion' started by Frank Tedesco, Apr 6, 2017.
  1. Frank Tedesco
    Frank Tedesco Junior Member
    Largo, Florida
    2001 Prius
    My 2001 Prius with 220k needs a 12v battery replacement for Panasonic S55D23L. Dealer wants $280 plus old battery!
    Is there a cheaper alternative? Optima says no.
    Brian in Tucson likes this.
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    If cost is a concern, there are some here that are using batteries that cost under $40.
    Or if you are looking for something that is less expensive and on par with the OEM option read this:
    Fitting mobility 12volt AGM battery. | PriusChat
  3. greasemonkey007
    greasemonkey007 Active Member
    286
    105
    South Central Arkansas
    Yes. I have found a local battery shop that can get me factory blems for less than 1/2 price. Check around!
  4. JC91006
    16,482
    8,400
    Factory blems? Like the ones that charge up to 11.9v?
  5. greasemonkey007
    286
    105
    I bought 3 of them a couple of days ago, and put 1 in today. It was the larger size battery, rated at 325cca. It was putting out 395, as seen on his tester and mine. Voltage appeared normal when I put it in. I guess time will tell.
    Brian in Tucson and bisco like this.
  6. bisco
    49,509
    normal being 13 volts? are these yuasa?
  7. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
  8. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    In Tucson, we have a place that reconditions sulfated batteries. They sell blems, too. They peel all the labels off and brand it "blem." I'm running one in one of my cars. Just as good as a Deka (it is a Deka) and it only cost $55. Pretty cool.
  9. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    If you take your old dead battery to Autozone they'll give you $10, btw.
  10. Cofi
    Cofi Junior Member
    57
    Co springs co
    2001 Prius
    I
    Optima quality has gone to shit since moving production to Mexico imo
  11. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    The one in my Prius, installed last fall, seems to be just fine. Lots more affordable than the OEM one from Toyota, too.
  12. greasemonkey007
    286
    105
    yes, and yes.
  13. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Probably they can't get you a factory blem of the Prius battery. Prius battery is a very specialized one--quite small and a deep cycle. Most of the major battery distributors don't carry anything like that. Sorry.
    I wonder if a
  14. bisco
    49,509
    he says they are yuasa, which is the factory battery.
  15. greasemonkey007
    286
    105
    1 of the 3 had the decals removed. The other 2 looked like they came from the dealership. All tested great. Not sure who his supplier is. I've sold all 3 of them and waiting for him to get me some more.
  16. bisco
    49,509
    what are you doing with them?
  17. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    How much are you charging for them? AGM batteries can be shipped UPS or Fedex.
    In my past post, before I was pulled away for something else, I was wondering about using a Harley-esque motorcycle battery. Shorai makes really impressive LiFe Po batteries.
    The best answer is to maintain the 12v battery with a Battery Tender, I think.
  18. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    You can easily use a different size battery. There are threads about converting the post using a marine post terminal with screw on wingnut adapter, and using a standard universal negative post type cable. All parts can even be found at walmart, cheaply. Take out the oem battery hold down brakets and make your own out of either some wood or rigid foam to fit your new battery. I did this on mine and am using an old optima red top i had laying around. The original Prius battery was tiny, only 27mah. Alot of uninterruptible battery backups have more capacity!
