My brother’s 2003 Prius help won’t start
Discussion in 'Generation 1 Prius Discussion' started by Priuslover09, Mar 3, 2020.
  1. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    My brother went to start his car and it wouldn’t start he got the code
    P3125 and he touch the inverter and it burning red hot. He called the Toyota dealership today and they told him it would be over 6,000$. He lives in below Indianapolis and he needs some options otherwise he would be needing a ride from his gf that has a ford focus xl 2000
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    Feel free to use google.....................
    kenoarto likes this.
  3. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    again I use yahoo
  4. TMR-JWAP
    6,404
    6,088
    Columbia, SC
    Maybe that's part of the problem with not being able to find good solutions? Google is everyone's friend if you have a question. Yahoo is great if you like reading about the Kardashians latest news
    kenoarto and dig4dirt like this.
  5. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    Did anyone check the level of coolant for the inverter coolant system? This will be the reservoir at the top center when you look under the hood. It should be between the min/max marks and look nice and red / dark pink.
    The P3125 can come with a any number of "subcodes." Do you also have a subcode? (There are a lot of them. See here: P3125 - Toyota Prius Hybrid Fault Code Diagnosis - Rennacs) In other words, basic Pxxxx codes rarely point to any magic bullet. They're just starting points for diagnosis. On that note...
    Do not take a car like this to a dealer. Ads aside, dealer service departments can give a rat's tail about true "service." Everyone who walks through the door is just a cash cow, and that is all. Ask around among people you know and use ... well, whatever internet search strategy you want... to see if you have any reputable, locally owned, independent shops that specialize in prius/hybrid work and use them instead.
    mroberds, WHCSC and Georgejaunty18 like this.
  6. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Yes my brother did
  7. zpi28
    zpi28 New Member
    Arkansas
    2003 Prius
    Do you or your brother have any automotive troubleshooting experience? It will take some knowledge of cars and some electrical knowledge helps as well with this car. Do you know where the inverter coolant pump is? its behind the drivers headlight. Need to check it to see if its pumping. It should be running with the key on.
    Had your brother been driving the car prior to getting the code? Had he already been driving the car before he touched the inverter?
    mroberds likes this.
