My car cut off on me a couple times I changed the battery and it turned on but it stopped again
Discussion in 'Gen 2 Prius Fuel Economy' started by Makail McGee, Aug 11, 2017.
Tags:
  1. Makail McGee
    Makail McGee New Member
    Corpus Christi
    My car cut off on me a couple times I changed the battery and it turned on but it stopped again and the caution sign popped up again.
  2. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    Which battery: 12v or HV? Trouble lights have trouble codes that will tell you what's going on. Need to get them read. Check the 12v voltage and connections.
    51,939
    cutting off is not usually a 12v problem, but maybe connections?
  4. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    As mentioned above, have to get the error codes read. Could be a failed inverter coolant pump, and the hybrid system is shutting down when the inverter temp gets too warm. Or low coolant in the inverter coolant system.
