My car keeps shocking me.
Discussion in 'Gen 3 Prius Main Forum' started by octavia, Dec 12, 2009.
  1. octavia
    octavia Active Member
    968
    137
    Beautiful Oregon
    Someone suggested that a nearby lightning strike might have effected my sks and it got me to thinking.
    My car shocks me a lot. I have a history of getting shocked, something about me seems to attract stray electricity and I get some pretty good zaps from touching door handles, plugging things in, etc. It's enough of an issue that I have developed little habits to deal with it, like running the back of my hand along something first or touching it with my shoulder first, or asking someone else to plug things in or unplug them.
    I am so used to it that I didn't realize that my car has given me some real zingers lately. Something about the cold weather, and me wearing sweaters maybe? It's gotten to wear my hair is so full of static electricity that touching IT shocks me.
    Could that have anything to do with my sks being so fickle?
    I didn't really think of this particular implication when I bought a hybrid, but it makes sense now that I think about it.
    I wonder if there is anything I can do to become less prone to shocks?
  2. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    Are you talking about static electricity shocks? I used to get those all the time for a while on my old pickup. It was to the point that I was in the habit of opening the door and then touching it with the back of my hand to get it over with, it just became second nature.
    But what I really want to know is did you try your second key/fob to see if it works fine?
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The Prius has been good to me in that respect. I rarely get shocked by it. Now my GMC and Chevy trucks used to shock the heck out of me! I always figured it was due to the high wattage stereo systems though. :eek:
  4. octavia
    968
    137
    Beautiful Oregon
    I haven't.... but I will today. :)
    *runs off to fine the alleged second key that must have come with her car that she knows-not where it is. *
  5. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    210
    San Diego, California
    This is shocking news!! :faint:
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    It's not the SKS. It's your cloths. For example, some sweaters can generate quite a lot. Anything with "spandex" in them will also give you a jolt (my "Sportif" hiking pants for example, but underwear not so much as it's covered -usually- ;) ). Any "slippery" nylon or polyester garmets can also generate enough to be troublesome.
    All this is just a nuisance, but be careful. If you succeed in sparking to a piece of electronics (a button for example), it -can- damage the electronics!
    Especially watch out when fueling the car. The spark -can- ignite fuel vapours! So touch the car body from the outside -before- you reach for the pump, and don't get in and out of the car while fueling.
  7. kenmce
    kenmce High Voltage Member
    1,530
    507
    NY
    It may be that you have low rolling resistance tires and that being low in carbon, they allow static charge to build up on the vehicle. You could try dangling a chain or cable from the frame to ground, like ambulances do, and see if that changes anything. You could also develop the habit of touching the car with a key or something each time you come up to it, so the spark jumps at the key.
  8. garygid
    garygid Senior Member - Blizzard Pearl
    379
    23
    Orange County, CA
    I have the same Prius model and options, and no static electricity problems at all.
    Yes, check for rubbing or sliding clothing (and shoes) generating static.
    It is probably YOU shocking the Prius (and other grounded items),
    and not the car (and other items) shocking you!
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I've seen her racy posts in the Online Dating thread and I'm inclined to agree! ;)
  10. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Me too, I have had many pleasant dreams as a result
    Seriously, every new vehicle I have driven since 1998 or so, appear to zap me to some degree. Much worse in winter with dry air, sweaters, etc
    Amazing true winter fact: always "ground" yourself before giving a smooch. Some folks like a spark at their lips, but not me
  11. sciguy125
    sciguy125 Junior Member
    CA
    Coincidentally, I started doing research on this recently because I was tired of my car zapping me. My job is to figure out how to protect microchips from static, so i decided to figure out how to protect myself...
    The studies that I read (apparently, people write papers about this) make me think that it's us zapping the car, not the car zapping us. When you slide out of the seat, you can pick up much more charge than you normally would running around your house. So, you can get a much nastier zap than you would from a doorknob. Of course, this depends on your clothes and the material on the seat. Things get worse in winter because the cold air drops the water content in the air (and you're more likely to wear static prone clothes).
    The best thing I've been able to figure out so far is to get out differently. The more you rub against the seat, the more charge you pick up. I've been trying to roll out instead of sliding out. Keeping constant contact with part of the body (metal) while you get out would help too. Sometimes, I put my leg against the door sill and use it as leverage.
    On my old car, I used to hold the key and use that to discharge myself to the door because it hurts less. Of course, now I don't have a key...
  12. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    Try spraying your driver's seat with a very mild solution of fabric softener to eliminate static electricity.
    Keith
  13. LeadingEdgeBoomer
    289
    29
    New Mexico
    You know those warnings at the gas pump you never read? Watch this, please:
    The woman had gone back into her car after starting the pump, then got out without grounding to get rid of static electricity. Got the zap when she touched the gas nozzle!!! So always discharge before handling the pump, every time you get out of your car Nowadays tires have more silica, and are not so good at grounding the car. I've read that Static Guard sprayed onto cloth upholstery can help, but I have no experience with that. Leather-faced seats might also help. In any case, leaving the gas nozzle unattended is a bad practice.
  14. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Polyester pants!
  15. going red baby!
    610
    96
    Los Angeles
    That's also why you're not supposed to use a cell phone at the gas station.
    Pretty brave of her to grab that nozzle. So is there no danger of explosion? It looked like it was just flaming at the end and not traveling up the line or anything. I suppose they have a safeguard built in for that.
  16. 008
    008 New Member
    CA
    Wow. That video is disturbing. I have a 15m and a 5 yr old and getting them out in a hurry is easier said than done... The lady was lucky, it could've been worse.
    This car/cloth interior does zapp me A LOT more than my previous car (G35/leather) and come to think of it, my G hardly ever zapped me. I'm thinking its got more to do with the material of the interior.
  17. cychosis
    cychosis New Member
    Portland, Oregon
    We just had a very dry, very cold stretch of days here in Portland (OR), and our '10 Prius was shocking the crap out of us. It really hurt.
    Yesterday, I bought an anti-static strip from the local auto parts store, jacked up the rear of the car, found a nice mounting (hole already provided) spot on what I assume is the rear-wheel stabilizer beam, and attached it.
    Of the more than a dozen times we've exited the car since, we've been very, very slightly shocked twice, the remaining times nothing.
    $6 solution.
    Cheers,
    Ron
  18. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Octavia must be secretly working on a plan to convert her Regular Hybrid into a PHEV Hybrid! :)
    If we could now capture all her static to charge the Hybrid Battery!
    Octavia...try some static guard if your having a bad time of it...;)
  19. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    If you don't mind leather interior, it helps in reducing static shock.
    My old Odyssey and Prius had the static shock problem, especially in dry winter climate. After installing leather seat covers in my Prius, problem is now gone.
    IMHO, it is mainly caused by the friction beween your clothes and the cloth seat cover. When the seat cover is leather, static charge does not happen.
  20. octavia
    968
    137
    Beautiful Oregon
    hmmm.... I've discovered modal material lately. I love it so much I bought a bunch of tanks made of it to wear all the time. I wonder if it's making the problem worse?
    Innocent little ol' me? And this whole time I thought I was keeping my racier side hidden....
    I don't think they call those "dreams." Just sayin.
    Agreed! As far as I'm concerned there is nothing at all sexy about electricity.
    *passes on the obvious opportunity to make innapropriate comments here*
    See... Nothing racy at all.
    In Oregon they don't let us pump our own gas. I hadn't pumped my own gas until a few years ago when I visited Wa. A friend snapped a picture to commemorate the experience.
    I wish!
    I will... I think I'm a candidate for static guard if anyone is. :)
