My dad sabotaged my brakes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wjh308, Feb 10, 2013.
  1. wjh308
    wjh308 Junior Member
    22
    San Francisco
    You know, I told my Dad to not touch my 2007 Prius before fully researching changing the brake fluid. I was going to do it myself but he could not wait!
    He went to bleed the rear brakes, and the abs system locked out the wheel he was bleeding...
    The manual I have says to use the scan tool, all the web pages I viewed said to use a scan tool to reset the code... He read it and thought he knew better!!!!
    MY FAULT FOR LETTING HIM TOUCH MY CAR!
    SO my question is this... Which scan tool do I need to do a proper brake job on the Prius? Will any code reader do or do I need the fancy one with the extended features that plugs into the laptop?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    OTOH, yes. The proper way is w/Toyota Techstream, which is software that runs on a Windows laptop w/a special OBD2 cable.
  3. wjh308
    22
    San Francisco
    How about the Auto Ingenuity with Toyota addon?
  4. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    I believe the Mini VCI cable of Ebay comes with the Toyota software that allows you to do this. The VCI is a Chinese cloned Mongoose cable and the software pirated Techstream.
    John (Britprius)
    nh7o and wjh308 like this.
  5. PriusCamper
    PriusCamper Senior Member
    11,105
    4,518
    Pacific Northwest, USA
    There's a thread on here from a guy who figured out how to do it with a paperclip in the ODBII port... Basically you need to get the car in a state where the electronics controlling the brake system are disable so you can bleed the brakes normally. I'll do some digging and see if I can find that link....
  6. PriusCamper
    11,105
    4,518
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    If he broke it, he pays to fix it. :)
    A learning curve for all involved.
  8. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Might want to give Luscious Garage in San Francisco a call, they should be able to get you back on the road for a reasonable price.
    richard schumacher likes this.
