My DIY custom tachometer scan gauge
Discussion in 'Gen 4 Prius Accessories and Modifications' started by neiman, Nov 25, 2020.
  1. neiman
    neiman New Member
    Truckee, CA
    2020 Prius
    LE AWD-e
    I am very excited to share my project with this forum! I have spent the last few months working on it in my spare time.
    I have been very curious about the mysterious behavior of my Prius. I decided to create this scan gauge to view RPM and engine temp. It is powered by an Arduino microcontroller and a CAN bus controller. I decided to take the hard route so there is no traditional ELM327 (regular bluetooth or usb) scan tool hardware in this project!
    I have code posted on GitHub if anyone is interested in making their own.
    WilDavis and Mendel Leisk like this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    I presume it's ICE RPM, not MG1 or MG2.
    All I can think - yes, it will give you very curious readings. There was talk on, I think the LEXUS forum about a hybrid with a tachometer - and it seemed to not be useful. Just a curiosity.
  3. Mendel Leisk
    38,644
    It could be reading anything? Coolant temp'd be cool too.
    Sorry, initial post says this is possible.
    #3 Mendel Leisk, Nov 25, 2020
    alanclarkeau likes this.
  4. fuzzy1
    10,150
    Any connection to the MPGuino, talked about some here and on other efficiency and modder forums since before my time?
  5. neiman
    neiman New Member
    Truckee, CA
    2020 Prius
    LE AWD-e
    Ah yes, I've seen that before. That was one of my sources of inspiration. MPGuino has a simpler principle of operation. My design is a little bit more complicated...uses OBD protocol over the CAN bus. I could really request any data I wanted from the ECU.
    fuzzy1 likes this.
  6. neiman
    neiman New Member
    Truckee, CA
    2020 Prius
    LE AWD-e
    It is indeed ICE RPM. I am very curious to read what the traction motor RPMs are. It may give me more insight into the vehicle's top speed on electric only power. I know that there are a whole bunch of Prius-specific PIDs that can be requested from the ECU. I am very curious to see what I can find out from tinkering and experimenting.
  7. Mendel Leisk
    38,644
    There's a spreadsheet on the net listing scangauge xgauges, might be helpful.
  8. neiman
    neiman New Member
    Truckee, CA
    2020 Prius
    LE AWD-e
    This bad boy right here?
    Will require some poking around. This will be a challenge since those don't look like regular OBD PIDs. I'm not sure how exactly they are implemented in the scan gauge. Something to keep me busy I suppose.
  9. Mendel Leisk
    38,644
    Yes I believe so. Just viewing on phone currently, so looks a little odd.
  10. neiman
    neiman New Member
    Truckee, CA
    2020 Prius
    LE AWD-e
    krmcg likes this.
