My DRL acting weird?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by SwhitePC, Jan 17, 2014.
  1. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    I always have my car in DRL, and just noticed last night to today that it doesn't turn on immediately when I start the car, however it does seem to turn on a few minutes after the car starts rolling. I'm sure before it turned on immediately with the car.
    Any ideas? maybe 12v going weak?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    If it's anything like my factory DRLs in my Camry, it will be deactivated when the parking brake is engaged or the transmission is in Park.
    So the delay you are referring to is most likely when you put the car in drive and disengage the parking brake.
    Could it be possible that you had the headlight selector switch set to lowbeams previously? In that situation, starting the car with the light switch in the lowbeam position will turn on the headlights immediately when the car is put into Ready or Acc Mode.
    SCH-I535
  3. DKTVAV
    DKTVAV Active Member
    510
    101
    On my C as soon as the "ready" is on the DRLs turn on, the OP has the C2 not regular liftback like yours.
    OP, switch problem? Try to turn on and off few times to see if it helps.
  4. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    They are off as long as the e brake is on. H
  5. DKTVAV
    510
    101
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    There is a position on the stalk for DRLs off. Did you bump it or is it an every time thing?
  7. SwhitePC
    495
    214
    ca
    aw, I see thank you all for the insights, I think it is the ebrake, lol my bad
    I just got scared thinking my bulbs burned out or something Last night
  8. DKTVAV
    510
    101
    So you were driving with eBrake? I have to check it but when the first time driving my sister's Lexus 250 CT I couldn't move the car when the eBrake is not released and the indicator "Brake" is turned on.
  9. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    1 click shouldn't be able to stop the car, but it will make an audible beep (vs an inaudible beep... long day, sorry) and have the brake light illuminated.
  10. SwhitePC
    495
    214
    ca
    no I wasn't driving with the ebrake. But I was parked on a hill for 1st time in a whil, hence I had my ebrake on and didn't see my drl come on when I started car, so it just sort of surprised me.
    I did check all my lights to see that they were all working, I just didn't know that ebrake on = no DRL on start up
    So I guess I'm still learning something new everyday about my C
