My EV, ECO and POWER mode bottons does not activate on my 2012 prius
Discussion in 'Gen 3 Prius Main Forum' started by Chuba, Sep 16, 2019.
  1. Chuba
    Chuba Junior Member
    45
    Nigeria
    My EV, ECO and POWER mode bottons does not activate on my 2012 prius.
    When ever I start the car it shows on ev on my dash and can go off and on depending on how I am driving. But me changing to ev or eco mode or power mode by pressing any of the 3 bottons does not work.
    Please who have had this issue before and how do I fix it?
    There is no error codes showing. Is just that the bottons does not activate
    49,430
    it is eco/normal/power modes, and ev/hv modes. they are not the same.
    how long have you owned it, and when did the issue arise?
  3. tvpierce
    tvpierce Senior Member
    949
    879
    Maine
    2013 Prius v wagon
    Is it a Prius V wagon?
    49,430
    why do you ask?
  5. tvpierce
    949
    879
    Maine
    2013 Prius v wagon
    Because the location of those buttons in the V Wagon (horizontal on the armrest) make them extremely susceptible to collecting spilled drinks, and general "gunk" -- rendering them inoperable. When I bought my V used, the buttons didn't work at all. I had to remove the switch cluster, then disassemble and clean it.
    It's a pretty dumb location for a set of switches that rarely get used. Almost as dumb as the location for the heated seat switches -- which are tucked down low out of sight so you can't see them unless you're a Hobbit.
    ASRDogman and bisco like this.
  6. Chuba
    Chuba Junior Member
    45
    Nigeria
    No!
    Prius 2012
  7. tvpierce
    949
    879
    Maine
    2013 Prius v wagon
    All I can offer is to remove the switch cluster and clean it.
  8. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    277
    Redwood City, California
    I have a 2012 Prius v, new to me, still getting used to it, figuring things out, so if something does not make sense to me I assume it's working properly and I don't yet understand why.
    So anyway, I've got similar sounding doubts with my buttons. For me, the buttons seem to be just fine. I can press them however I like, and I get instant confirmation up on the dash based on what I pressed. The "problem" is that after doing that, the car seems to switch to whatever mode it wants as soon as it feels a need to do so. So for example, my requests for EV mode are literally (not really) laughed at after a minute or so at most.
    Just wondering if this is related to the OP's issue. The dash should instantly respond to any button pushes. I think if it does/does not that would tell you if there is a problem with the buttons themselves. What happens after that is a different issue (or non-issue).
  9. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    It will drop out of EV when EV is inappropriate for any of various good reasons (or if the engine is cool). It will drop out of Power mode when you restart after shut-down. Otherwise, it should not change from whichever mode you select.
    2012 Prius v wagon 3 likes this.
