My Favourite Recipe
Discussion in 'Fred's House of Pancakes' started by bevspark, Dec 17, 2009.
  1. bevspark
    bevspark Toyota, Major Sponsors of The
    707
    27
    Adelaide; South Australia
    Nana's Favourite Trifle
    Ingredients:
    2 x 85g Original Port Wine Jelly
    1 x 300g sponge or jam roll, sliced
    1 x 800g can peach slices, drained (keep juice)
    2 tbsp peach juice
    750ml thick custard
    1 cup (250ml) cream, whipped
    Method:
    1. Prepare jelly according to pack instructions, refigerate until just beginning to set.
    2. While setting, line a 1.5L glass bowl with sponge slices, pressing into base and drizzle with peach juice. Top with drained peach slices. Pour all but one cup of jelly over peaches and allow to set firmly in the fridge. Set the remaining cup of jelly in a shallow bowl, and then crush with a fork.
    3. When trifle is set, top with custard, whipped cream and crushed jelly. Or decorate as you like.
    For a more traditional trifle substitute the peach juice for 2 tbsp of sherry or port.
  2. a_gray_prius
    2,927
    782
    IL
    Bastard on the beach:
    Part 1:
    1 shot fresh lime juice
    4 shots chilled ginger ale
    dash of angostura bitters
    1 shot rum
    1 shot gin
    Shake ingredients together, pour into glass filled with ice, garnish with mint sprig
    Part 2:
    1 shot brandy
    1 shot gin
    1 shot rum
    ½ shot lime juice
    1 dash bitters
    1 shot Ginger Ale
    mix, repeat with ice filled glass.
    Part 3:
    1 shot brandy
    1 shot bourbon
    1 shot gin
    1 shot rum
    ½ shot lime juice
    1 dash bitters
    1 shot Ginger Ale
    Part 4:
    Pass out.
    2 people like this.
  3. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Will do!
    Yep, describes me perfectly!
    Works for me
  4. bevspark
    707
    27
    And when you vomit up all that alcohol, guess what it looks like. Trifle!!!!!!! :sick::p
  5. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    Pecan Pie Bars
    3c flour
    1/2c conf sugar
    pinch salt
    1teas vanilla
    1 cup butter or marg (cold/diced)
    Mix in large bowl or food processor to crumb stage. Press into 10x15x1 1/2 in pan. Bake at 350 for 20 minutes.
    Meanwhile mix:
    5 eggs
    1 1/2c sugar
    1 1/2c corn syrup (you can adjust this with a bit of maple syrup if you want)
    3 Tb melted butter
    1 1/2 teas vanilla
    4 cups chopped pecans
    Pour into crust and bake for additional 25-30 minutes. Be careful though cause once you make this it will become a frequent request, people will climb over each other and hide pieces for later consumption, it will get ugly!!
  6. bevspark
    707
    27
    Mmmmmmmmmm I am gooing to give this one a try. Does C mean cup?
  7. SPEEDEAMON
    SPEEDEAMON Professional Car Nut
    1,556
    606
    Los Angeles
    Polpettone al Forno (Italian Meat Loaf)
    Polpettone
    Tuscan bread 4 slices (you can use any bread)
    Extra lean ground beef (1 3/4 lbs)
    Ground pork (1/4 lbs)
    Prosciutto (1/4 lbs) finely chopped
    Extra virgin olive oil
    Garlic (4 or 5 cloves to your liking) finley chopped
    Red onion (1 large) finely chopped
    Eggs (2 whole beaten lightly)
    Italian Parsley (1/4 cup) leaves only, finely chopped
    Parmigiano Reggiano (1 cup freshly grated)
    Bread crumbs (2 cups fine)
    Salt and freshly cracked black pepper
    Milk (1 cup)
    Lemon zest (optional)
    Salsa Pomidori (tomato sauce)
    Garlic (2 or 3 cloves to your liking) finely chopped
    Bay leaf
    Dried chili pepper (4) optional
    Canned Italian tomatoes with liquid (2 cans 28oz each)
    Dry Red wine (1 cup)
    Italian Parsley (2 tbs) leaves only finely chopped
    DIRECTIONS:
    Preheat oven to 375°F.
    Chop the onion and garlic fine. In a skillet, pour some olive oil and when heated saute the finely chopped garlic and onions until transparent and set aside to cool. You can remove just the garlic when it starts to brown and set it aside first.
    Remove the crust and break the bread into small pieces and soak them in the milk. Drain the milk and with your hand squeeze the bread into a mush.
    In a large bowl, mix with your hands the beef, pork, Prosciutto, bread, eggs, parsley, Parmigiano together with the room temperature onions and garlic. Add salt and freshly cracked black pepper to your taste. Knead together until the mixture is well integrated and the feeling is slightly tacky. The more you knead, the better the texture.
    Sprinkle the bread crumbs evenly on a sheet of aluminum foil and shape the mixture into a rectangular loaf. Carefully roll the loaf on the crumbs so that all sides are uniformly coated. Don’t forget the ends. You can use a another sheet of aluminum foil to wrap the loaf from the top to help maintain the rectangular shape.
    In a baking dish or roasting pan, pour some olive oil and gently place the meat loaf in the center. With a brush, coat all surfaces of the meat loaf with olive oil being carefull not to remove any bread crumbs. Bake for 35 to 45 minutes until golden brown.
    While the polpettone is in the oven prepare the tomato sauce. Open the cans of tomato and remove the seeds either using a tomato press or by spoon. Put the tomatoes and liquid in a blender and chop the tomatoes so its not totally pureed. Heat up the olive oil in a sauce pan over medium heat. Add the garlic and optional chili pepper and saute until it changes color. Add the tomatoes and juice from the cans and stir in the salt and pepper and red peppers. Bring to a boil and add the red wine. Cook 8 to 10 minutes and add and stir in the parsley.
    Take the polpettone out and using a spoon, carefully remove the impurities that seeped to the surface or dripping down the sides and any that are floating on the bottom including oil. This is very important for a healthy recipe. Now tilt the baking dish and remove about 3/4 of the remaining liquid. Pour the tomato sauce over the meat loaf and mix it with the remaining liquid in the pan and cook another 15 minutes. Remove from the oven and wait at least 5 minutes before cutting.
    Spoon the sauce over each serving and sprinkle lemon zest on top if you like.
    Buon Apettito!
  8. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    I don't usually use recipes, and seldom follow them even when I do. Baking requires more precision than cooking, but I pretty much wing it when it comes to meals. Like, stir fry has mostly veggies, but apples and even mango and papaya are pretty tasty. Spices are a little of this and a little of that...hmm, needs more something...I'll try this. :)
  9. Salsawonder
    1,897
    47
    La Mesa California
    This is so me! I have a hard time when I make up my own recipes though if I don't write some of it down as then it is difficult to recreate. I do not buy any type of nut butter, that is what food processors are for, neither do I buy salad dressing....I love shaking up something special in a little jar.
  10. Salsawonder
    1,897
    47
    La Mesa California
    Yes, not good at conversions.......you can be inexact with this recipe, it is forgiving.
  11. SPEEDEAMON
    1,556
    606
    Los Angeles
    Tired of the same ol' appetizer for New Year's Eve? Super Bowl? Then try this
    MUSHROOMS SEGOVIA
    Prepare one day ahead
    Ingredients
    1lb common brown mushroom de-stemmed and cleaned. Choose small buttons
    1/4 lb ground pork or finely chopped pork
    2 - 3 slices Jamon Serrano or Prosciutto di Parma or baked ham (not smoked) finely chopped
    2-3 cloves garlic finely chopped
    Extra Virgin olive oil
    1 cup Dry white wine
    1/2 tsp red hot pepper
    3 tbs parsely leaves only finely chopped
    sea salt and freshly cracked black pepper
    Directions:
    Clean and de-stem the mushrooms using a brush. cut those that are big into halves
    Pour olive oil in a medium pot, 1/4 cup to start with, add the mushrooms and saute for 5 minutes under medium heat. Add more olive oil as the mushrooms soak it up so that it won't evaporate and dry up.
    Add the garlic and hot pepper flakes. Then add pork, finely chopped Jamon or Prosciutto or ham, parsely, salt and pepper and saute for 3 minutes mixing along the way. Then add the white wine and evaporate.
    Take off the stove to cool down and leave in fridge over night. Re-heat and serve with toothpicks, whatever. When all the ushrooms are gone, dunk bread into the remaining liquid and eat the left over pork. yummm
  12. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I'm taking Vegan Jalapeno Poppers for New Year's:
    A pile of jalapeno peppers, with seeds removed. Try to leave as much of the pepper intact as possible
    A tub of Tofutti Vegan "cream cheese" spread*
    1/2 cup corn meal
    2 Tbls Eat in the Raw brand Vegan Parmesan substitute, Chipolte Cayenne style*
    Using a teaspoon, stuff about a teaspoon of cream cheese into each pepper. Dampen stuffed peppers slightly, then roll in the mixture of corn meal and parmesan. Arrange on lightly greased baking pan, and bake for 20 minutes, at 350F.
    Let cool slightly, and eat!
    *Vegan items are generally available at larger grocery stores, Trader Joes, Whole Earth Foods, or health food stores that carry grocery items. I get mine at the Olympia Food Co-op. I've seen them at Fred Meyer's, as well.
  13. Darwood
    Darwood Senior Member
    5,259
    268
    Crepes
    1 and third cups milk
    1 cup flour
    1 and a half eggs
    teaspoon oil
    teaspoon sugar
    pinch of salt
    pinch of baking powder
    Butter up a griddle on medium heat and pour some on. Smooth it around with a flat spatula to make a thin even layer. The first one I usually throw out as a primer to get the excess butter off and the rest cook perfect. Roll or fold them up and top with powedered sugar etc.
  14. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    So, Darwood, do you use roses, carnations, or daisies? :p
  15. Darwood
    5,259
    268
    :p
    (fixed)
  16. a_gray_prius
    2,927
    782
    IL
    Irish Car Bomb (I can see a few of these being consumed tonight):
    1 shot of whiskey
    1 shot of Bailey's Irish Cream
    1 bottle Guinness
    Fill glass with Guinness, pour shot of Whiskey on top. Add shot glass full of Bailey's to mix and chug quickly when it starts to foam.
  17. Darwood
    5,259
    268
    Purple hooter:
    Shot of vodka
    shot of Chambour
    Lemon sour
    Another of my favorite breakfasts:
    Pannekoeken:
    1/2 cup flour
    1/2 cup milk
    2 eggs
    Heat oven to 350. Put a tablespoon of butter in a ceramic pie pan in the oven till it melts (this helps get the pan to the proper temp). Pull out and add the above mixture and sprinkle cinnamon and nutmeg on top. Put it back in the oven and watch it rise for about 25 minutes or till the rising sides get dark brown.
    Add powdered sugar and enjoy.
  18. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    Vegan Waffles
    1 large banana
    1/2 cup rolled oats
    1 & 1/2 cup whole wheat flour (yes, you can use white flour if you are a wuss)
    2 tsp baking powder
    1 tsp cinnamon
    1/4 tsp nutmeg
    1/2 tsp vanilla
    2 cups water
    Blend all together in a blender, pour onto pre-heated, greased (this is important!!) waffle iron. Bake as usual. you can also make these as pancakes. My waffle iron takes 4 minutes, 30 seconds to bake them perfectly. Serve with Earth Balance spread and maple syrup :p
    You have to grease the waffle iron because there is virtually no fat/oil in the batter, and they will stick!
  19. samiam
    samiam Antipodean Prius Poster
    2,442
    29
    Enn Zed
    Pavlova
    The Pavlova is a wonderful Kiwi dessert served at any holiday piss up (festive occasion). The pavlova is so good that Aussies try to claim it as their own. (The first known published recipe was in E. Futter 1926 “Home Cookery for New Zealandâ€. Yet the Aussies claim to have created the pavlova 1935 – typical.)
    Ingredients
    For the base:
    $10
    1 bicycle
    OR
    4 egg whites
    1 teaspoon vanilla essence
    ¼ teaspoon salt
    1 teaspoon vinegar
    1 cup castor sugar
    2 teaspoons cornflour (cornstarch)
    For the topping:
    1 cup (240 ml) heavy whipping cream
    1 1/2 tablespoons (20 grams) granulated white sugar
    1/2 teaspoon pure vanilla extract
    sliced fresh fruit - kiwi, strawberries, bannana
    Cooking instructions
    Get on your bike, and take the $10 to the corner store. Purchase a boxed pavlova and take it home and make the topping.
    OR
    Preheat the oven to 150°C.
    Beat egg whites and salt in a bowl until soft peaks form. Gradually add the castor sugar while beating. Continue until stiff peaks form. Beat in the remaining ingredients, vanilla essence, vinegar and cornflour. Turn mixture out onto a baking paper covered tray. Shape into a circle approximately 23 cm (9 in) in diameter.
    Reduce oven temperature to 140°C. Bake for 15 minutes, then further reduce the oven temperature to 120°C and bake for 1 ¼ hours. Cool completely in the oven.
    Whichever method you have used to acquire your pavlova base, just before serving gently place the pav onto a serving plate. Whip the cream in your electric mixer, with the whisk attachment, until soft peaks form. Sweeten with the sugar and vanilla and then softly spread the whipped cream over the entire pavlova. Arrange the sliced fruit randomly or in a decorative pattern, on top of the cream. Serve immediately as this dessert does not hold for more than a few hours.
    Pour champagne, slice pav, enjoy...
  20. bevspark
    707
    27
