My first time using Dr. Prius - are these numbers good?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by amaranth, Feb 10, 2026.
  1. amaranth
    amaranth New Member
    Washington State
    2014 Prius v wagon
    Hello everyone, this is my first time posting on this forum. I'm trying to learn more about the hybrid battery system and eventually become a Prius wizard.
    Currently driving a 2014 Prius V with close to 80k miles on it. Car currently runs fine, and an OBDII scanner shows zero error codes, but I think the hybrid battery has gotten significantly worse since buying it at 70k miles last year. "EV mode" seems to last for less distance every time I try it, and EV mode will end (engine restarts) at much lower speeds than it used to. Also my gas mileage is slowly getting worse - average dropped from about 40 to about 37. All this makes me suspect that the hybrid battery is dying.
    I downloaded Dr. Prius and ran a battery monitor log (spreadsheet attached) while idling the car. I kept an eye on the "VOLT DIFF" statistic while doing it - VOLT DIFF is not reported on the spreadsheet but it hovered around 0.04-0.08V while the car was idling. Is that bad? I've heard it should always be zero on a healthy battery.
    Is there anything else I should be looking for in these test logs? Do I need to buy the full version of Dr. Prius and do a full battery test to learn if my battery is going bad?
