My fix for the sun visors
Discussion in 'Gen 4 Prius Accessories and Modifications' started by priusgto, Apr 17, 2016.
  1. priusgto
    priusgto Active Member
    193
    227
    Northern Arizona
    Couldn't take one more day with the tiny useless sun visors and had no luck finding a decent extender so I decided to make my own. I made a wood template the same shape and size of the visors then molded a sheet of ABS plastic around it. This one should last the life of the car.
  2. glennonrp
    glennonrp Active Member
    178
    199
    Fontana, CA
    Four Touring
    I'm glad the visors don't bother me that much. A little. But not as much as they bothered you! :) I think if these were color matched to the visor then you could sell these. I might even buy a couple.
  3. priusgto
    193
    227
    Northern Arizona
    So far I've found ABS in black and white. The black looks great with the black interior. As for bothering me, these are the worst of any vehicle I have owned. I suppose if I were shorter than 5' 9, and sat closer to the steering wheel they would be adequate but as it is these are terrible in the Arizona sun.
    RCO, ETP and glennonrp like this.
  4. glennonrp
    178
    199
    Fontana, CA
    Four Touring
    I'm 5'7"! Maybe that explains it. I have the moonstone. So, both would stand out too much for my tastes.
    I'm not hating on your work. It's impressive that you managed to make them look like something you could buy. If they were the right color and were made so that they wouldn't mar the visors or head liner then I bet you sell them.
    priusgto likes this.
  5. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
  6. priusgto
    193
    227
    Northern Arizona
    Amazon.
    I'mJp likes this.
  7. bisco
    49,494
    brilliant! absolute genius, well done!(y)
  8. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    What was the abs plastic sheet thickness ? Whats your recommended thickness ?
    jp
  9. kenoarto
    kenoarto Senior Member
    396
    Chicago, IL
    Nice work .... but the better solution is flat visor extensions held in place by a rubberband/ponytail band for tilting/swiveling. It is THE most perfect solution for driving directly in to the sun and low sunsets, etc. I used black cardboard. Matching plastic would be even better.
    #9 kenoarto, Apr 19, 2016
  10. priusgto
    193
    227
    Northern Arizona
    I used 3/32" material and it worked well. 1/16" would work well also.
    I'mJp likes this.
  11. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    What would you charge us if we wanted you to make a set?
    kenoarto likes this.
  12. priusgto
    193
    227
    Northern Arizona
    The black ABS material for one side cost me between 5 and 6 bucks so to make two, about $25.00
  13. plug-it-in
    plug-it-in Active Member
    179
    113
    Kitchener, ON, Canada
  14. bisco
    49,494
    i wish i had the o/p's talent. i made one out of paperboard and elastics. it doesn't slide that well, but i also made a fold down flap to cover lower glass area. i need to do some refining!
    #14 bisco, May 26, 2016
    ETP likes this.
  15. kevindb
    kevindb Junior Member
    Baltimore, MD
    In the pictures, it looks good enough to have been manufactured. You're very skilled!
    After the (relatively) HUGE visor in my Sonata with built-in extender, I'm tired of having my retinas burned out with the tiny little visor in my Prius.
    If you're taking orders, you can put me down for one, please! :)
    pjm877 likes this.
  16. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    How did you mold the ABS sheet around the wooden form, heat gun and oven mitts, or something like a spatula/putty knife to fold and press the sheet into shape?
    I have the woodworking skills to make the visor form, but need a little guidance on the molding part lol.
  17. xliderider
    7,869
    3,116
    Honolulu, HI
  18. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    I would be interested at those prices. I did see some sites that advertised custom colors. I wonder if we could get sheets color matched close to the color of the actual visor. If we can maybe we can get a good group buy price.
    If not I would prefer grey or white over black.
  19. pjm877
    pjm877 Member
    340
    84
    austin, tx
    Put me down for a set...
  20. priusgto
    193
    227
    Northern Arizona
    Yes I used a heat gun. I clamped the whole assembly in my large vise with the wood visor on one side of the ABS and another piece of wood on the other side. I slowly/evenly heated the ABS until it was soft enough to droop on it's own over the edge of the wooden visor, then using a 1x3 block of wood I continued it around and held it in place for about one minute to let it cool. I used 3/32" material but I'd suggest using 1/16" so it's not so rigid.
    For you guys wanting a set, sorry but I don't plan on making any to sell. I have too many irons in the fire right now.
