my fuel gauge is broken? (post accident)....
Discussion in 'Gen 3 Prius Main Forum' started by deltron3030, Dec 26, 2009.
  1. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    hey guys my gas gauge is out of whack,
    here are the most recent variables possibly factoring into my current problem:
    1. I hit a pretty big rock in the road (about the size of half a cinder block) just small enough to fit under the car, but i definitely heard it bashing the underside of my car and saw it flying in pieces out the back. checked underneath the next day, no visible damage outside of scratches.
    2. just had 18" wheels/tires installed on the car. same overall circumference as stock. mpg is down about 5mpg, but that shouldn't cause my problem below.
    3. when i fill up, i wait til the pump stops. wait 20 seconds, and give it one more squeeze. i never get more than a half a second of top-off, and i only do it once.
    now, my fuel gauge is on average 2 pips too low, even after a full fill up, the highest pip is at the bottom of the "F" on the gauge. I considered that the display may be busted, except, there are a few minutes after the fill up, where the gauge reads properly full, then i'll turn off the car, and its back to wrong the next day.
    the gauge consistently reflects usage though. the pips disappear correctly and consistant with how far ive driven, but when the last pip blinks, i just know i have more in the tank than it says.
    help?
  2. dogfriend
    7,512
    1,190
    Carmichael, CA
    I do not have a service manual for a 2010, but for my 07, there is a calibration procedure that can be done if the gauge does not read correctly. IIRC, it requires a Toyota scan tool. Edit: (correction, I guess you don't need the scan tool, see post below.) If I were you, I would take it to the dealer (you could wait until the next service since it isn't going to cause any additional problems) and ask them if they can take a look at it since you should still be under warranty. I wouldn't mention the big rock unless they do. I doubt that that caused the issue with the guage unless you caved in the tank or something.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
