My Gas Motor turns on as soon as touch the accelerator
Discussion in 'Gen 2 Prius Fuel Economy' started by grccmetech, Feb 12, 2018.
  1. grccmetech
    grccmetech New Member
    grand rapids mi
    As soon as I push the gas, even if I lightly tap it, the gas engine turns on. its effecting my gas mileage I am currently getting 22-32 depending on how much highway driving I do. I have replaced both o2 sensors because it was throwing a code and acting up terribly, but now its good except the electric motor doesn't engage without the gas motor engaging aswell. I also changed the fuel injectors spark plugs and the oil. finally swapped 12v battery but even the new battery still is at 11.6V after overnight the old one was at 11V so I don't know if that has anything to do with the inverter or not. please help
  2. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Welcome to PriusChat!!
    How many miles on this vehicle?
    How did you read the thrown codes previously?
    Raytheeagle likes this.
  3. grccmetech
    grand rapids mi
    273k I read it with a snap on scanner
  4. Drafty01
    Drafty01 Junior Member
    42
    Auckland, New Zealand
    What voltage does your 12V battery charge at? Should be about 14.0 to 14.5V.
    11.6V is basically flat, and will likely ruin it in a short time.
  5. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    This.
    Sounds like the HV side of the equation is not working properly or possibly at all. Usual suspects: inverter, inverter pump and/or HV battery weak/failed.
  6. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    Your HV battery pack might be heading South already. No matter what you do, until the HV part of the equation is sorted out, before you'd get a relief.
  7. grccmetech
    grand rapids mi
    ya i definitely suspect the hv battery. my aux battery does charge at 14.1V. The inverter pump is working, and the inverter itself has to be working because the car drives fine for the past 3 months. I happen to have access to a snap on scanner so I can read the voltages of the individual cells in the hv battery. i am planning on testing them after letting it sit 24hrs to see if i can get away with replacing just a couple modules. my question is, is there any other way to test the hv battery?
  8. bisco
    51,758
    i think torque pro is a decent prius scanner.
    but i have concerns about the second 12v battery you installed. is it new? did you check the voltage before installation?
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,089
    Columbia, SC
    The Prius is typically pretty darn good at coding an HV battery when it's getting to be time to replace it. If there's no HV battery codes, I don't know that I would focus a lot of energy or money in that direction. If your brand new 12v battery is 11.6v, I think I'd rectify that situation first. Put a low amp charger on it and top it off. My manual says it should be limited to 3.5 amps.
    Start with the obvious things first. Tearing into the HV battery with no codes seems like unwarranted business to me.
    Get a good 12v charge, re-install the battery, and test it out. Just keep in mind you've put new O2 sensors in, and cleared all the ecu maps when the 12 v was off. And I'm sure the weather is cold as a witches t*t where you are. None of those things are immediate positive things in your corner. What injectors/plugs and oil did you install? Is Techstream available to you?
    jerrymildred likes this.
  10. uart
    uart Senior Member
    4,220
    1,209
    Australia
    The main things I've noticed that can cause the engine to be a bit "hair triggered" in wanting to start like that are:
    1. A weak HV battery.
    2. Low state of charge (4 or less bars on the energy monitor screen).
    3. Very high temperatures (including blocked rear cooling fan).
    4. Very low temperatures.
    Before worrying too much about number 1 on the list, check if any of the others are applicable. Have you checked the rear cooling fan for blockages (dust,fur,lint etc).
  11. Astrong1984
    Astrong1984 New Member
    Castle Rock Colorado
    This may sound rudimentary, but do you have the heat on, and is it cold outside? I am in Colorado and when it is cold out, both of my Gen2s act that way.
  12. grccmetech
    grand rapids mi
    i am going to test the HV cells today after letting them sit over night. and ill test the12v battery before returning it.
  13. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    It' an 06, the traction battery is 12 years old, just buy a new from Toyota traction battery and get five years of 50+ mpg, and make sure that the plugs you put in are good, your mileage is really low, missing cylinder low.
    Last word was Toyota is selling the traction for 2000$, not a bad deal, did you buy a new 12v or swap a used one?
    Is your air pressure 40, is your emergency brake cable binding?
  14. grccmetech
    grand rapids mi
    i let the car sit overnight and all the voltages are within .2v. i tested the 12v out of the car and it passed the test. im starting to think that the average mpg is off. i recorded my miles when i filled up so i will do the math at the end of the week. my battery fan works too btw i did a test on the snap on scanner
  15. grccmetech
    grand rapids mi
    i will add that at 40% SOC the volts were at 15 i dont know if that has anything to do with anything
  16. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    That scanner looks pretty advanced, like to the point of being able to scan/log/play back live data.
    Can you scan while putting a load on the HV battery?
  17. grccmetech
    grand rapids mi
    ya i push the gas or put it in reverse not much seems to happen with the voltages
  18. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    How are you guy's MPG when its super cold? Should we see low 30s when the car typically gets 40s mpg in regular weather?
    audiodave likes this.
  19. audiodave
    audiodave Active Member
    799
    270
    US
    Trickle charger the 12volt couple times a week. Car charger sucks.
  20. audiodave
    799
    270
    US
    Did you notice improvements in power after the injectors where replaced?
