My gas tank cap doesn't click
Discussion in 'Gen 3 Prius Main Forum' started by dsharp88, Jul 13, 2010.
  1. dsharp88
    dsharp88 New Member
    New Orleans
    It says to turn until it clicks once, but mine won't click. I can turn it just so far and no more, but never a click. It seems perfectly tight. Is it OK?
  2. EmuMessenger
    EmuMessenger New Member
    35
    Collierville, TN
    Mine definitely only clicks once. It has been an adjustment since all previous cars would click many times. The click is not very loud.
  3. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    Isn't there a specific dash warning for an untightened gas cap? Years ago, the 'loose gas cap' was a big issue in that it would turn on the 'check engine soon' light. In a panic, people would take their vehicle in for service, only to find it was just the gas cap.
    Eventually, automotive ECM's were programmed well enough that they would recognize 'non-fatal' warnings such as a loose gas cap. The warning would appear briefly, the code would be stored (presumably to be cleared the next time the vehicle was at the dealer), and the light would go out.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    As far as the warning, it is still the check engine light (yellow triangle) that will light in this case.
    As mentioned, the click is very faint on the Prius.
  5. polpo
    polpo Junior Member
    Cupertino, CA
    It's more of a metallic "tink" than the plastic "click" that people are used to on gas caps.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    I think things on a new car should work the way they are suppose to, I'd take it in and have it fixed. It might work forever the way it is or it might start leaking as soon as the warranty is up. :eek:
  7. GBC_Texas_Prius
    218
    38
    gbc texas
    Time to break out the channel locks and give the cap a serious turn.
    Seriously, my salesman said to bring the car back in if there some minor issue or question like that. Call the dealer and have them demonstrate what to watch for. If it doesn't work, then they need to fix it.
    I was used to my Matrix that made multiple clicks, so the first time with the Prius, I also wasn't for sure if it was sealing correctly.
  8. johalareewi
    johalareewi Member
    393
    44
    uk
    The Prius cap is a bit different to other caps I have seen. The Prius cap only does one quiet click and that is it. On the Yaris, the cap goes click-click-click-click very loudly. I'd second popping into the dealer so they can show you what should happen. If it doesn't happen, you are in the right place for a fix!
  9. erikl
    erikl New Member
    36
    SF Bay Area
    +1 for a quiet click.
  10. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    Is there really a warning light if the gas cap is not properly closed? is it mentioned on the user's manual?
  11. tumbleweed
    4,067
    687
    Eastern Oregon
    I don't think there is a warning light that says "the gas cap is loose". It turns on the check engine light because the gas tank is no longer pressure tight indicating and emission control problem.
  12. rudiger
    696
    45
    Cincinnati, OH
    If the problem is resolved (i.e., the gas cap is tightened correctly), although a trouble code is stored is the ECM, doesn't the 'check engine soon' light eventually go out on its own?
  13. pakitt
    2,173
    1,311
    Colorado
    Will try once with mine to see what happens - I'loose it and see if get any beep or flashing light on the dashboard...
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It should after 3 cycles to power on and off. If not, that might indicate another problem.
  15. bisco
    49,446
    coincidentally, the engine light came on in my wifes hycam the other day. thanks to some threads here, i checked the gas cap and it was almost completely loose. i turned the car on and off four times allowing the engine to come on for a minute each time. the light is still on. we'll drive it for a few days to see if it resets itself before taking it to the dealer.
  16. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Go to an auto parts store that reads codes for free then research it. If it something serious take it to the dealer. If it sounds like a loose gas cap just clear it. A real problem will trip the light again.
  17. bisco
    49,446
    how do you clear it? i know how to reset the oil change light. thanks!
  18. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It requires an OBD2 reader that handles the CAN protocol ($75-$150). AutoZone (and PepBoys) will read and reset the code for free using one of their OBD2 readers.
    JeffD
  19. gbarry
    gbarry Junior Member
    79
    16
    S. California
    You can see it on page 501, but you'll learn more here than you will from reading that.
  20. KJF
    KJF Member
    75
    17
    Small town - north central Idaho
