My headlight washers r bad
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Dinesh Jayasinghe, Jan 7, 2016.
  1. Dinesh Jayasinghe
    Dinesh Jayasinghe New Member
    Colombo
    Okay, I tried my headlight washers. Right side works, but not the left one. The jet just keeps popped out, must be a malfunction. How to fix is a problem....I dont use them much, actually never had the reason to use them up to now. But would like to fix the issue.
    49,504
    might be clogged, try running a small wire through it, or disconnecting inside and blow backward with compressed air.
  3. Dinesh Jayasinghe
    Colombo
    Thanks Will try and see...
