My High Mileage '08 Prius needs a new battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SuzB, Aug 9, 2022.
  1. SuzB
    SuzB Junior Member
    Los Angeles
    Four Touring
    Hi. I'm not new, but returning. I believe my '08 Touring Prius will need a replacement Hybrid Battery. The warning light is on, the AC has stopped, cruise control not working. I'm stopping driving it until I can fix the problem. Any suggestions besides the very expensive new battery, or taking it to a dealer?
  2. JC91006
    16,768
    8,565
    There is a shop in Rosemead that I often use for service, Armstrong Auto Services. Maybe you just have a failed inverter pump? You can check easily by opening the inverter coolant reservoir (when you open the hood, it's directly in front of you with pink fluid), when the car is in READY mode, see if the fluid is moving. If there is no movement in the fluid, then you have a failed pump
    51,932
    how high are the miles?
  4. RovinRon
    RovinRon Junior Member
    33
    22
    Federal Way WA./Sun City AZ.
    Far from an expert, but I would have 12 volt house battery checked first. Lot less expensive!!
