My impressions after changing shocks/struts at 130k miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by alekska, Jun 6, 2012.
  1. alekska
    alekska Active Member
    435
    138
    Atl
    Hi all,
    just wanted to share my experience after changing front and rear shocks on my 2005 Prius with 130k miles.
    1. Rear of the car felt "twitchy" when riding over uneven pavement in turns, so I decided to change rear shocks. Purchased original Toyota OEM rear shocks, and changed them myself. Taking the trunk interior apart took longer than the shock replacement itself. In general it's not too hard if you have experience with other cars.
    After the removal, old shocks were not that different in feel from the new ones when I tried to stretch/compress them by hand. Replaced them anyway. The ride over bumps did not change dramatically. I might feel slight improvement, but maybe it's just a biased perception. The ride is still not perfect, but now I think its a feature of a solid rear axle design.
    2. Front: The ride was ok, but I did feel the "surge" (momentary braking decrease) during braking on uneven pavement several times recently, though I was prepared and new what it was. Also, there was slight clunk when riding over bumps which, based on my previous experience with cars, I attributed to slightly worn sway bar bushings. So I purchased KYB struts for the front (non-adjustable, GR2), and new strut mounts and spring insulators. Changed them myself. While in there, I checked the sway bar bushings, and they were perfectly fine. Old strut mounts seemed perfectly fine too, but I replaced them anyway. Also I have found one of the rubber sleeves that protect the strut rod from dirt was torn (I had new ones to replace).
    After the repair, I felt noticeable improvement in the way car rides over bumps and in braking. Not a single braking "surge" since the replacement of front shocks!
    So in my case, 130k miles on the car driven on decent roads in Atlanta, rear shocks were ok and probably would lasted longer, but front ones really needed replacement, even though there was no leaks and "push/release" test showed no excessive bouncing.
    Hope this will add my 0.02 to the discussions on "when to change shocks/struts"
    Thanks,
    - Alex
  2. Mike Mc
    Mike Mc '16 Prius 4, '13 Prius 3
    88
    35
    Fort Worth
    Nice write up!
  3. Patrick Wong
    18,200
    6,479
    Thanks for sharing your experience, I agree that it is quite possible for the struts/shocks to fail without visible fluid leakage. I also agree that pushing on a fender of the Prius is a useless exercise with regards to assessing the condition of the struts/shocks.
    Did you try to compress the original front struts by hand & compare to a new part?
    I changed the rear shocks on my 2004 a couple of years ago after my daughter (riding in the back seat) complained of a bad ride. As the driver it was less noticeable to me. However after replacing the shocks the ride was back to normal and the complaints disappeared.
  4. alekska
    435
    138
    Atl
    Patrick,
    Yes, I tested the front struts by hand and they were easier to compress/extend than the new KYB. It's hard to tell how much easier. Also another thing that I noticed was larger " low resistance area" around middle position, I.e. just between compressing and extending.
    Thanks,
    - Alex
    quote="Patrick Wong, post: 1573216, member: 37850"]Thanks for sharing your experience, I agree that it is quite possible for the struts/shocks to fail without visible fluid leakage. I also agree that pushing on a fender of the Prius is a useless exercise with regards to assessing the condition of the struts/shocks.
    I changed the rear shocks on my 2004 a couple of years ago after my daughter (riding in the back seat) complained of a bad ride. As the driver it was less noticeable to me. However after replacing the shocks the ride was back to normal and the complaints disappeared.[/quote]
  5. The Critic
    The Critic Resident Critic
    3,193
    2,322
    CA
    Interestingly enough, I am already beginning to notice this on my 2011 at 34.5k. Perhaps I should replace my struts.
    Glad you were able to tackle the job yourself, as this one is a pricey one.
  6. Patrick Wong
    18,200
    6,479
    I suggest you first check the tread depth of your front tires, and if marginal, replace those now.
  7. The Critic
    3,193
    2,322
    CA
    9/32" all around, just had a new set of Energy Saver A/S installed in the last 6k. Alignments are also dialed in perfectly with spicer shims and Toyota camber bolts.
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Thanks for the information. I replaced mine somewhere between 120k and 130k I think. They were pret bad but not leaking. Doing a compression and rebound test by hand it was pretty obvious they were "bad". I probably beat on mine too much. /)
  9. DHV
    DHV Junior Member
    Sandy, Utah
    How do you remove the plastic caps covering the nuts holding the strut mount assembly onto the strut shaft?
  10. Patrick Wong
    18,200
    6,479
    Just pry the cap off with a small flat-blade screwdriver.
