My intake ports @ 150k miles (NASTY!..)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Dec 26, 2018.
  1. iskoos
    iskoos Active Member
    401
    246
    Orlando, FL
    I finally tackled this job a few weeks ago. I was not expecting nice looking intake ports after those 150k miles but what I saw was way beyond my imagination.
    Just wanted to share a few pictures for you. You are looking at the #4 cylinder intake. Picture taken as soon as the manifold was removed. I didn't touch anything. The carbon pieces could easily be finger picked!..
    I was originally thinking the intake cleaning would take me a day or two in the garage. But after seeing how bad the intake ports were, the total job took several days, countless hours of tedious cleaning with different methods.
    I was able to clean all 4 intakes to a decent level but I couldn't reach the end of each intake and clean the walls around the valves. It would have been possible to remove those carbon built-up but wouldn't have been possible to remove them entirely. I even tried a strong shop vac. It didn't work.
    After cleaning the intake manifold (Yes, it was full of oil!..), the ports, and the PCV (it was still rattling @ 150kmiles), I did an oil change and installed an oil catch can. This was 1000 miles ago. All is working fine so far.
    I replaced intake manifold and throttle body gaskets, PCV cleaned up not replaced.
    Soon, I will be replacing the spark plugs, getting down to EGR cooler and clean that part as well. I expect a similar condition down there.
    I used NutzAboutBolts videos. Thanks to them for everything...
    20181119_181750.jpg 20181123_170548.jpg 20181119_184439.jpg 20181123_223416.jpg 20181123_230535.jpg 20181119_152333.jpg
    Pluggo, m.wynn, RMB and 5 others like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    I bet you’re glad you pulled off the intake manifold;).
    It looks pretty dirty:eek:.
    Does your Prius consume oil?
    Glad to hear the videos helped as we lobbied @NutzAboutBolts to create them :).
    The egr cooler will be a good one to tackle next when convenient(y).
    m.wynn and NutzAboutBolts like this.
  3. iskoos
    401
    246
    Orlando, FL
    Nope, it doesn't consume oil. More accurately, it doesn't consume enough to the point that I realize and add oil.
    Every high mileage car should consume some oil I guess.
    Plus all that oil goes from PCV into the intake should count as consumable:eek:
    Raytheeagle likes this.
    49,500
    how many miles does everyone estimate the engine actually ran on a 150k prius?
  5. iskoos
    401
    246
    Orlando, FL
    You mean how many of those 150k miles were ICE vs EV miles?
    If so, I would love to know that as well. My buddy has Ford C-Max Energi and his onboard computer records total EV miles vs ICE (gas engine) miles. Anytime the ICE is off and the wheels are rolling counts as EV miles.
  6. bisco
    49,500
    i think gen 4 might, if you keep one of the trip meters rolling
  7. Mendel Leisk
    38,729
    Thinking how the heck you can clean all the way down to the valves, and without flushing stuff into the cylinder.
    First off, you'd want to ensure both the intake valves are closed on the port you're cleaning, by cranking the engine, say with a ratchet and extensions through the passenger side wheel well.
    Then some sort of brush, maybe brass bristle, on a long extension, at slow speed on a drill? Coupled with carb cleaner? Maybe a Dremel, to not overpower it.
    Or stick with hand tools.
    I recall @NutzAboutBolts cautioning too: to try not to foul the fuel injector tips when cleaning.
  8. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    That definition seems highly arbitrary. By that definition, you could easily accumulate a significant fraction of "EV miles" in a non-hybrid vehicle, coasting downhill or to stops with engine off.
  9. gliderman
    gliderman Active Member
    751
    223
    You would need total run time, total miles, engine run time, miles and gas consumption to understand the ICE/EV mode ratio, which will be unique to each vehicle. Unless Toyota has that info already calculated somewhere that is accessible.
    I know we always talk about miles as a gauge for everything, when instead it should be time.
    YMMV
  10. bisco
    49,500
    it's all in pandora's box
    m.wynn, padroo and Raytheeagle like this.
  11. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Don’t open that:eek:.
    Hope you don’t have the key:p.
    m.wynn, bisco and padroo like this.
  12. iskoos
    401
    246
    Orlando, FL
    My first idea was to soften the buildup with brake/carb cleaner and use a wet cloth (soaked with brake cleaner) to wipe the inner surface of each intake port. It seemed to work but the buildup was so thick that I wasn't getting anywhere. I had to find a more effective method.
    I checked the intake valves and except for the cylinder #1, all were closed. Being extra cautious with cylinder #1, I shoved piece of cloth into each intake port all the way to the valve area. I made sure valve areas sealed well. Then I took my trusty flathead screw driver:) and started scraping the intake surfaces one by one:eek: Once the thick material was out (and you wouldn't believe the amount of stuff I got out!..), it was easy to clean the remaining thin layer of carbon with a help of brake cleaner and paper towel.
    This cleaning didn't get done in a few hours though. Took several days of tedious cleaning. I did clean the entire carbon deposits (or whatever it was) off the intake port surfaces. Did check the valve area with an inspection camera and utility mirror to see if anything large dropped in there. Small pieces shouldn't have been a problem since some must have been already being sucked into the cylinder every day.
    I do remember picking up a few pieces with a curved tweezer. I also used a shopvac but I didn't find it effective. I didn't have the right attachment to do a good job in that tight area.
    Overall, I did pretty well. Maybe it wasn't necessary to do this level of cleaning but since I was already there, I said why not? and did it.
    One cannot pay me to do it once again though. I am done with it for good:)
    And as for the injector tips, I was being careful with them. I cleaned the buildup around the tips but didn't touch the tips directly.
    Next up is the infamous EGR cooler...(y)
    20181123_170217.jpg 20181123_170144.jpg 20181123_205649.jpg 20181123_223416.jpg
  13. JC91006
    16,482
    8,400
    I started this maintenance last week but I started with the EGR circuit and cooler. I was debating on tackling the intake manifold this coming week, but there seems to be a TSB for that item, I can get it replaced instead of cleaning it.
    But looking at your pictures, I may want to take a look at this myself......
    Raytheeagle and RMB like this.
  14. Mendel Leisk
    38,729
  15. iskoos
    401
    246
    Orlando, FL
    80% of the cleaning done was on the engine block. Just a little part was on the manifold itself. You aren't getting away with any of those cleaning jobs if you get that manifold replaced:)
    Raytheeagle and JC91006 like this.
  16. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    I did a completely lay person estimate that actual usage time on these little ICE is about 2/3 what a non-hybrid car would be. I want to claim 1/2 but that's certain to signal the release of the hounds.
    Mendel Leisk and bisco like this.
  17. egn83b
    egn83b Junior Member
    59
    Rarford nc
    I clean my intake every 50k miles. The prius runs too rich since toyota updated my car a few years ago. I noticed my 60 mpg went to 45 and never came back. The issue with the intake can be fixed with a catch can. My car has not burnt a drop of oil since new. Normally i use brake cleaner to melt the carbon rubish and wash the intake with dawn soap and brushes. Takes me 4 hours from start to finish.
  18. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    775
    360
    I'd feel like I thief if I had one of these in my shop and told someone it was necessary to do any of this. I'm kind of amazed at what the internet can convince people to do.
    RMB and kc5dlo like this.
  19. iskoos
    401
    246
    Orlando, FL
    Every 50k miles. Wow. You worse than me. I won't ever see that portion of my car ever again.:)..
    I installed a catch can and I believe in it. However, I do not think all that carbon rubbish is the result of oil getting into the intake. EGR system must be responsible for some of it.
  20. iskoos
    401
    246
    Orlando, FL
    You are absolutely right. My car was running the same way before and after. I didn't realize anything (nor was I expecting). It is just us DIYers get bored time to time and we love our cars.:)
    I would recommend cleaning the intake (getting that puddle of oil out of there) and installing a catch can (if a person can do it). That should be enough. No crazy cleaning as I did here will be required...
    Mendel Leisk and m.wynn like this.
