My little red C-Biscuit has paint problems!
Discussion in 'Prius c Main Forum' started by rosethornil, Jun 16, 2021.
  1. rosethornil
    rosethornil Member
    47
    30
    Virginia
    2016 Prius c
    It’s a 2016, trim level 1, and the Barcelona Red paint looks rough. On the hood, there are probably 25 little chips and it goes right down to the white primer.
    It’s got 84,000 miles and it also has the 3M protection on the lower 1/3rd of the hood. Under that 3M covering, the paint is pristine.
    Does the “C” have cheaper paint? Does trim level matter?
    I keep the car good and clean, and it’s been garaged most of its life. Frankly, I’m disappointed in the paint job.
    Thanks for any insights.
    52,761
    toyota has cheaper paint, it's not uncommon. one of the things they don't excel at
  3. rosethornil
    rosethornil Member
    47
    30
    Virginia
    2016 Prius c
    Is this unique to the C? Or to the C-1?
    As I said, it’s been garaged most of its life and it looks rough.
    52,761
    Not that I have read
  5. Mendel Leisk
    42,249
  6. Leadfoot J. McCoalroller
    8,264
    7,768
    Pennsylvania
    2018 Prius c
    The c is shaped for aerodynamics. One of the side-effects of this design is that if the air sweeping around the car has anything suspended in it (like small rocks) they are all but guaranteed to hit that frontal surface, either on the paint or the glass. Gravity being what it is, the lower area is favored for strikes and that's where the paint is.
    Thusly we've collected many small rock chips on the hood of our own c. I've now done 2 touch-up sessions to clean and fill the chips; it is turning into an annual exercise.
    I made peace with this long ago- it's a sacrifice for MPG. I'm good enough at filling, sealing and feathering the chips that I haven't had rust or further degradation. The rest of the car is going to look old and tired before the hood stands out.
    rosethornil likes this.
  7. rosethornil
    rosethornil Member
    47
    30
    Virginia
    2016 Prius c
    Thanks so much for your reply. That’s very helpful.
    My little car averages 50+ mpg so maybe I just need to accept that this is what happens with these phenomenal cars.
    Thanks again.
