My observations on our C
Discussion in 'Prius c Main Forum' started by TrailRunner, Mar 8, 2012.
  1. TrailRunner
    TrailRunner New Member
    CA
    Although my profile says we own a 2012 Prius four, it's really a 2012 Prius C, four.
    So far we love the car.
    I am frustrated by the gearshift, however. Having driven a Prius since 2005, it's a pain to now have to shift into Park, then press Power. Were I King, I would edict "Away with the shifter, back with the dongle"!
    Speaking of 'back', there is no 'beeping' sound when in reverse on our C. I'm not sure if I like that or not.
    We now have over 50 miles on the car, half freeway, half city, and the car tells us we're getting 35 miles to the gallon. We're expecting to see substantial improvement in that area as the car 'breaks in'.
    Our car has 16" wheels. Multiple times when parking, I've hit the steering wheel stops as my mind seems to think I should have been able to turn a little more sharply. I didn't test drive a 15" wheeled C so I don't know if hitting the stops is something I would do on that car, too.
    Several people have commented on the headrests reducing the rear view. Since there are just two of us, we leave the seats down and it helps a bit.
    As more thoughts occur, we'll post them.
  2. Sunkiss'd C
    Sunkiss'd C Junior Member
    51
    Riverside
    yes, the headrests do obstruct much of the rear view, but its not surprising given the size of the car. One thing that I do like about the C over the current gen Prius is that it doesn't have that ridiculous foot parking brake.
  3. Tideland Prius
    16,158
    Congrats!
    Ohh, is there not a Prius c option? We'll get that fixed!
  4. smokiejoe
    smokiejoe Member
    178
    30
    PA
    Best of Luck. You'll have to report Gas Mileage after a few weeks.
    Thanks.
  5. strongbad
    strongbad Member
    170
    47
    Driggs, ID
    A couple of the online car test sites have reported a big difference in turning circle between the 15" wheels and 16" wheels. MotorTrend measured 31.4ft for the 15s and 37.4ft(!) for the 16s.
  6. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    211
    used to be "Glacial" Maine and now FL
    Don't understand why Toyota decided to de-dongle the c. Bad move for those of us that will be trading rides between a Liftback (or v) and a c. What were they thinking?
    No reverse beep? Does the ICE stay on when you back up? At first I thought the beep was a nuisance, but it is very quiet in our Prii while doing the EV backing up routine and it could go unnoticed!
    That 35 MPG figure is a little scary. Might want to check your tire pressures. What kind of conditions and temperatures were you driving in. The lowest MPG figure I ever saw on our '05 Prius was 42, and that was coming home in a snow storm with high winds and temperatures around 10 degrees F.
    Glad to see you're going to give us some updates on your observation. I think the c is going to be a great car.
  7. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    According to Toyota, they were looking for a more "mainstream" look and feel. This also explains why the front is not as much like a Prius. You have to keep in mind that the c is not a Prius everywhere else in the world; the concept of a Prius Family is exclusive to the United States. In every other country, the c is just a fun-to-drive Toyota hybrid and that's it. The audience they are appealing to are not typically downsizing from a Liftback to a c.
  8. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    You mean like:
    Basically, the car's designed for 15s.
  9. Tideland Prius
    16,158
    And 14s. The base Toyota Aqua L in Japan rides on 14" rims.
  10. phenoyz
    phenoyz Member
    108
    nevada
    Update on this, i think there is something wrong???
    What about going uphill does the car struggle?
  11. HabaneroBomb
    HabaneroBomb Junior Member
    62
    Gilroy Ca.
    I bet the reading of 35 mpg was due to a short, under one mile trip! Don't worry your car's fine.
  12. HabaneroBomb
    62
    Gilroy Ca.
    Or, maybe keeping up with traffic 80mph.
  13. outhouse
    outhouse Member
    125
    37
    auburn ca
    new C's need a litle breaking in.
    between 200 -300 miles mine broke in and I started getting 4mph more
    also there is a learning curve to driving these.
    fuel economy will go up another 4 with practice.
    rate it after a full tank of gas, and then on your second tank. you will see a difference between tanks
  14. TrailRunner
    CA
    Just completed our first fill up. The odometer reading was 396, the gas added was 8.67 gallons.
    Calculated mileage for the first tank was 45.67 per gallon. Trip A meter showed 45.1MPG.
    80% driving was city, 20% highway. Never above 71MPH on the highway. All city driving was below 38MPH.
    Needless to say, we're disappointed in our gas mileage.
    I'm wondering if our 'computer' is screwed up. The driving time on Trip A was 88+ hours - I'm not sure where that number comes from. At that rate it means I was driving 13.3 minute miles!
    The owner's manual says the ODO display should show MPG from the start (I assume that means from the beginning of the tank of gas), but on our car the ODO MPG zeros out each time we shut the car down. Maybe I'm missing a setting somewhere.
    After a couple weeks with the car I'm still hitting the stops on the steering wheel quite often. Were I to be buying this car now, knowing my experience with the car, I would definately get the 15" wheels with their much tighter turning radius.
    We're loving the Bluetooth connection with our iPod. We 'rip' multi-disk audio books and sync them to the iPod, then there is no need to change disks while driving. Very convenient!
  15. RichardAK
    RichardAK Member
    121
    Fairbanks, AK
    The tank may have not been full when you picked it up. That was the way it was for us. First tank 28 mpg by hand and 39 on the display. We'll see on the next tank.
  16. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    "From the start" means the start of that driving session. I don't think that can be altered (Trips A and B are for other mpg purposes).
  17. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I see no need for 16 inch tires on the Prius C. The 15 inch
    is all that is needed. Also the 16 inch tires probably takes
    a 2-3 mpg hit on your mpg. Maybe even more if their not
    inflated to near maximum sidewall pressued which is located
    on the side of each tire.Yes that mpg mileage is somewhat low. But it will get better as time goes on.
  18. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Trailrunner never mentioned anything about trip length which we all know is a killer on gas mileage for every car and could easily throw even the c into the mid 40s. Obviously the best advice is the refill the tank and get used to driving it, researching the fuel economy forums for the GenII and GenIII, and not sweating the small stuff. The monetary difference between 50mpg and 45mpg is pretty insignificant.
  19. TrailRunner
    CA
    The majority of our trips are in the 3-8 mile range, at sea level, in moderate temperatures (central coastal California).
  20. ItsNotAboutTheMoney
    2,287
    460
    Maine
    Moderate temperatures means what in Fahrenheit?
    And you aren't currently using the climate control?
    The shorter trips will hurt mileage as the engine warms up when you start your journeys.
    The 16" wheels don't help.
    The tires (and the car) still need break-in.
    Also, check tire pressures, just in case.
    Your mileage will vary.
