My oil isn't leaking anymore (257k miles)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sam Brinson, Sep 21, 2021.
  1. Sam Brinson
    Sam Brinson Junior Member
    Fort Wayne, Indiana
    I replaced the PCV valve, and tightened the oil filter a bit more from what the previous owner had it as (it was kinda loose.)
    Now, I accidentally overfilled my oil a bit during the last oil change, but thought it would be fine since the car leaks so much oil. After a few hundred miles, it's still above the maximum line on the dipstick and hasn't really moved. It's kind of bittersweet, and I just felt like sharing.
  2. JC91006
    16,480
    8,397
    Well these cars that burn oil do it when you're traveling at higher speeds. When you driving around town, it usually burns a lot less.
    You'll know if things are really better after a couple thousand miles of driving
