My Oil Report after 15k miles!!!!! :)
Discussion in 'Gen 2 Prius Main Forum' started by alexilic, Feb 1, 2010.
  1. alexilic
    alexilic Member
    120
    Wauconda, IL
    I accidentally got my next oil change milage mixed up and ended up going over 15k on the Mobile 1 and Toyota Filter. I was sure they were going to reprimand me...:director: but I was pleasantly surprised!! :rockon:
    What do you guys think?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Pretty freaking amazing isn't it.
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    In the winter no less.
  4. ksstathead
    ksstathead Active Member
    1,244
    244
    Kansas
    Congrats!
    Guess the stock filter is doing its job, too. Great to know. Although my gen3 is a different engine and filter, I expect similar results. Plan to change the first time between 5 and 10M, then go 10M unless I fail the normal service tests.
  5. alexilic
    alexilic Member
    120
    Wauconda, IL
    I just noticed that it was almost a full year between oil changes!! Since I do my own maintenance, that is a bonus!!
    BTW, I started doing my Moms Camrys oil change as well. I ended up pushing hers till 10k since thats what I'm used to on my Prius. I thought I'd send it in to see what kind of damage was done.. again, another pleasant surprise :D
  6. northwichita
    481
    102
    29
    Wichita KS
    From my previous driving experience I also extend oil changes to around 8k with regular oil, though I do drive my car all day long so little cold engine wear/condensation problems.
    The note about more miles=more iron on the report, my magnetic oil plug would take care of this, right? Just my recommendation, curious what the report would say with that installed, cheap insurance in my view.
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Edit to answer alexilic's question about where I got my magnetic plug without bumping this thread , I don't recall, probably ebay. The local auto shops did not stock them.
  7. alexilic
    alexilic Member
    120
    Wauconda, IL
    Where did you get your magnetic oil drain plug?
  8. risingsun
    risingsun seeker of the way
    186
    30
    Prescott, AZ
    You can get plugs on eBay. Just type in Prius Magnetic Plug. Or you can get them on Amazon or search for Gold Plug on Google...
