My Prime just did something weird while charging
Discussion in 'Prime Plug-in Charging' started by Lee Jay, Nov 13, 2018.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    I've never seen it do this before.
    What you are looking at is the allocated charge amount (the charge rate at which the charger is telling the car it can draw) and the actual amount the car drew. The short spikes to zero are normal. The long dips to 6A are what I've never seen before. It's cold right now but I've seen it charge in much colder temperatures than this (it's about 30F now) without doing this.
  2. hill
    8,207
    Balancing ?
    49,522
    battery performance changes over time?
  4. Lee Jay
    5,850
    4,024
    It didn't do it yesterday when it was 15F.
  5. bisco
    49,522
    software bug under the perfect conditions?
  6. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    Only thing I can think of is the charging unit in the car is limiting the charging current. The only reasons that would happen would be due to the temperature of the battery modules (there's 5 modules, 3 temp sensors in each module) being too cold or too hot. The charge current and battery output are controlled based on the temperatures (and other factors)...I would also agree that is odd for it to kick in...I could see it doing that if it was in the teens.
    A software/power glitch seems more likely, there is a tail towards the end of charging but that appears to be towards the last 1/3...
