my prius 2009 wont go into Drive mode.help plz.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Hussain777, Oct 9, 2019.
  1. Hussain777
    Hussain777 New Member
    Pakistan
    hello.
    my prius 2009 3rd gen, after starting wont go into Drive mode.
    12 v battery is new. kindly help.
    thanks
  2. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    Just to be very sure, you press the Power button while your foot is on the brake. After 5 seconds the Ready light appears and with your foot again on the brake you attempt to shift into Drive or Reverse, but nothing happens. That's a new problem. I hope you get a good answer.
    51,155
    welcome!
    make sure the brake lights come on when you press the pedal.
    if they do, test the 12v voltage at the battery, and at the jump point.
    check the battery connections, especially negative to ground.
    check all the fuses
    read the trouble codes
    all the best!(y)
    SFO likes this.
