My Prius has a blow off valve??
Discussion in 'Gen 3 Prius Main Forum' started by Acadianer, Feb 7, 2020.
  1. Acadianer
    Acadianer Member
    119
    82
    Technology
    So typically, my wife drive the Prius. A few weeks ago, she asked me to go fill it up, so I decided to use it for a tank and let her drive my Longhorn.
    Well I noticed this really odd noise coming from the fuel filler cap area. I’ve seen mentions of the cap perhaps not sealing properly or such, however wouldn’t that cause a engine light to come on???
    2010 Prius.
    49,429
    it does??
  3. Acadianer
    Acadianer Member
    119
    82
    Technology
    Sounds like a turbo’s blow off valve... but from the fuel filler.
    iPhone ?
    49,429
    might be a clogged/saturated charcoal cannister? but i would think a check engine light
  5. Acadianer
    Acadianer Member
    119
    82
    Technology
    Yeah, absolutely no engine light so far. I wanted to upload a clip, but can’t I guess.
    If it were the charcoal cannister, is that a replacement part or can it be cleaned?
    iPhone ?
  6. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    3rd and 4th gen Prii have a sealed tank, eliminating the need for the rubber bladder that plagued 2nd gen models in North America. The gas cap should seal and I have never heard any noise from any of my or my wife's Prii.
    If the charcoal canister was plugged, you would have problems filling the tank and I would think you'd also get a code.
  7. Acadianer
    Acadianer Member
    119
    82
    Technology
    Well, the last fill-up was actually annoying, I couldn’t keep the fuel nozzle on at max, because it would click as if the tank was full. This might be an indication that the canister is almost full.
    Can the canister be maintained or replaced easily?
    iPhone ?
  8. Mendel Leisk
    38,700
    How do you fill, ie stop when the nozzles first shuts off, or keep going, trying to top it right up?
  9. Acadianer
    Acadianer Member
    119
    82
    Technology
    Just asked my wife and she keeps going. I’ve read that it’s bad idea, especially for the Prius :-/
    iPhone ?
  10. bisco
    49,429
    I think you have to replace, maybe eBay
  11. jerrymildred
    11,508
    14,110
    Tampa, FL
    Yep, that's not good. It does sound like it's the charcoal canister. We had to have one replace years ago on a Camry for the same symptoms. I think I'd want to get confirmation with an experienced mechanic before spending money on something I'd read on the internet, because there are other things that might cause this. There are various vents and tubes involved, I think. I am fairly comfortable working on most stuff, but I when I looked at the canister replacement, I decided it didn't look like fun. Others probably feel differently.
  12. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Well with that many miles, time to trade in the wife for an upgrade.
  13. El Dobro
    El Dobro A Member
    6,978
    3,213
    Bad for just about any car. When the nozzle clicks off the first time, done.
