My Prius is down 4 quarts of oil 9000 miles after oil change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by southjerseycraig, Apr 13, 2017.
  1. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    My oil pressure light has been occasionally blinking, so I took the car to a service station I trust. They found that the car needed 4 quarts of oil. They didn't see a leak. I've never had anything like this before. Could it be something other than an oil leak? (The car has been running fine.) Is there any particular place an oil leak could be?
  2. fuzzy1
    10,150
    2010s are getting a reputation as oil burners. (Unfortunately, so is the engine series in my 2014 Forester. Someone has already filed a class action lawsuit.)
    Even absent that reputation, you are supposed to check the oil level much more frequently than once every 9000 miles. What about that maintenance check every 5000 miles? The fluid levels are supposed to be checked then, even if none are changed.
    Even new, the manufacturer doesn't consider it to be a warranty issue until consumption exceeds a liter (~quart) every 1000 km (~600 miles). This is in line with the rest of the industry. Manufacturers and customers are on very different pages on this issue.
    #2 fuzzy1, Apr 13, 2017
    Montgomery, dalcon95 and Merkey like this.
    49,375
    how many miles on her?
    isn't 4 quarts pretty much the whole shootin' match?
    audiodave, cwerdna and Raytheeagle like this.
  4. JC91006
    16,474
    8,393
    4 quarts would be close to everything in a gen3, minus the oil in the filter
    dalcon95 and cwerdna like this.
  5. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Yes. I did have the dealer do the five thousand mile check, and nothing unusual was reported. So maybe I've lost four gallons over the last four thousand miles -- yikes! The car has just about 89,000 miles on it, and I understand from other internet sites that the problem begins at about this mileage.
    Does this problem occur on all Generation 3's, or does 2010 seem exceptional? If the latter, that is further evidence that one should never buy a model in its first year of production -- I actually bought mine in the fall of 2009.
  6. bisco
    49,375
    hard to say. 2010's stand out, but they are the oldest. who knows, as 2011,12, etc. rack up miles.
    i seem to remember that toy made a change to the piston rings at some point, but not sure.
    you would be wise to start monitoring your oil level every day, then lengthening the interval as you gather data.
    dalcon95 and MPGesus like this.
  7. fuzzy1
    10,150
    Before this low level was discovered, when was the last time you personally checked the oil level?
    Never checking it yourself, between service visits, is a recipe and invitation for oil related problems. Based on before-Prius history, I also check the oil immediately after a service visit. Some shops handed off this job to the lowest paid trainees, some of whom produce undesirable work.
  8. Former Member 68813
    3,524
    981
    US
    OP, you have a burner now and no easy way to go back. Someone reported 10 techrone treatments fixed that in 2nd gen. If that really works (doubt it), it would be an easy fix.
  9. farmecologist
    farmecologist Senior Member
    1,946
    1,785
    Southern MN
    OP, just do some searching around here and you can see that you are not alone. The 2010s are absolutely are standing out as burners.
    Some of us have tried different things to fix it...with varying levels of success. However, I have seen very few people that claim to have conclusively 'fixed' it once it starts.
    Checking the oil has become a regular part of my 'routine'. I check it about once a week now.
    dalcon95 likes this.
  10. ETC(SS)
    6,542
    I do mine monthly....or every other fill up.
    Since I get 500 miles on a tank, it makes for easy math.
    Almost everybody under 30 these days neglect oil checks.
    Mostly, it's not that bad a thing since many cars have 5-6 quart sumps and 5-8k oil change intervals.
    Kids under 30 change out cars every 4-5 years, and so they never get a chance to wreck their motors by driving them for thousands of miles with 30-percent of the oil supply missing.
    Priuses only stand out as oil burners because they have small sumps and long oil change intervals (OCIs.)
    That means......if your dealer screws up and doesn't get enough oil in the sump (or puts too much in) then it's going to be as much as 10,000 miles before this condition is detected.
    Yeah......some people bring their cars to the dealer every 5K....but sometimes things get "accidentally" not done.
    The manual says check every month or every 1,000 miles. This is the second best way to prevent a screw-up at the dealership from REALLY hurting the car's longevity.
    The best way is to check and see if the dealer did it right by looking at the dipstick.
    It only takes ONE screw up for your car to start burning a liiiiiittle bit more oil than normal (all cars will use SOME oil between changes) and if you do not detect this condition early enough then the wear rate increases very rapidly before you "suddenly" have a car that burns oil........which is like "suddenly" having clogged arteries from eating too many cheeseburgers.
    I know a guy......who knows a guy who's busted an undisclosed car brand's dealerships more than once for not bothering to change out the oil filter.....and Prius filters are a PITA to begin with.
    They will be sprinkling rock salt on the sidewalks down in HELL before I let another dealership change my oil, but if I did, I'd make sure to check to see if the filter was changed as well.
    Mostly they are, because it's too easy to tell by looking at the oil on the stick if it hasn't been - but you'd be surprised how many people do not do this one basic check.
    Dealers don't use their $200/hr ace mechanics on oil changes.
    Just sayin....
    If you absolutely INSIST on a closed-hood maintenance philosophy, then have your oil changed every 5K.
    Good Luck.
    #10 ETC(SS), Apr 14, 2017
  11. farmecologist
    1,946
    1,785
    Southern MN
    I'm not sure who you are referring to in your post (probably the OP) but for the record ...I never let a third party change the oil. I have always done it myself.
  12. Mendel Leisk
    38,647
    Maybe instead of, or in addition to the US maintenance light, there should be a periodic prompt to check the oil? Say every 1000 miles. Something that's not a total pain to dismiss, but yeah.
  13. ETC(SS)
    6,542
    You probably also (not coincidentally) have a 2010 that.....like my work car, does not burn a measurable amount of oil.
    For the record, I was referring to MOST people under 30.
    Not all.
    Back in my youth, a little known activist coined a popular phrase about never trusting anyone over 30.
    He's 77 now, and I've always wondered if @ Jack Weinberg ever amended that point of view.
    I will say this....about that.
    There will never be anyone smarter than a person under 30, nor anyone more stupid than the parent of somebody under 30.
    Me?
    I have grandchildren....so I'm starting to get to be 'smart' again! :D
    If I ever buy a used car, it will probably be from a person under 30, but I will presume that the maintenance has been neglected and go from there.
    YMMV
    snead_c, farmecologist and Merkey like this.
  14. Mendel Leisk
    38,647
    Yeah I've got a 2010, with so far, knock on wood: zero consumption. That's a first for me, I'm used to a little oil going missing beteeen changes.
    So far I'm following a VERY short oil change interval, fwiw.
    #14 Mendel Leisk, Apr 14, 2017
    m.wynn and Merkey like this.
  15. southjerseycraig
    438
    107
    Cherry Hill, NJ
    The service station guy (whom I've worked with before, and who is quite good) made it clear that the oil needs to be checked every thousand miles. I guarantee that will happen.
    I don't like the idea of having an oil burner. In my over forty years of owning cars, I've never had this condition before. It makes me want to get rid of the car soon. But I like the gas mileage, and I don't know what to buy instead. The thought of buying a new Toyota bothers me; it seems to me that rewards them for incompetence.
  16. bisco
    49,375
    how bout the ionic? same mpg's, much better product. and they are gonna need all the help they can get, when their neighbors to the north decide to drop the big one on them.
  17. southjerseycraig
    438
    107
    Cherry Hill, NJ
    An Ioniq is an interesting idea. I did notice that the car is not CVT, but rather a "dual-clutch six-speed transmission." I would think that would make acceleration a lot less smooth than in the Prius.
  18. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,891
    Columbia, SC
    Since I've been in a pretty good groove lately, I'll go ahead and throw the BS flag on this one, too.
    "it seems to me that rewards them for incompetence."
    Seems pretty competent that a car went 9000 miles between oil changes and only burned 4 quarts............
    Certainly....."In my over forty years of owning cars, I've never had this condition before",
    Which condition is that?
    1. racking up 9000 miles between oil changes?
    2. burning a little oil between 9000 mile oil changes?
    3. that you've never had to check oil before?
    4. that you've never had to top off? In 40 years?
    That's odd, because I've never owned a car in my 33 years of driving that didn't need oil changes (at significantly less than 9k intervals) and top-offs now and then.
    Maybe....you caused your own 'burner'..........maybe you need to rethink where the incompetence might actually point to. It's mighty easy to point it at Toyota, but...........
    As evidenced by:
    What you really said was: After 40 years of driving I had no idea an oil light meant low oil pressure, so I kept driving the car. I never thought about checking oil level, because I really wanted to see if it would light solid so that annoying blinking would stop.....
    snead_c, tpenny67, xliderider and 4 others like this.
  19. southjerseycraig
    438
    107
    Cherry Hill, NJ
    In a car that the manufacturer says needs oil changes only every 10,000 miles, it is unreasonable for the car to burn through almost its entire oil in less than that time. You're the guy who needs the BS flag!
  20. TMR-JWAP
    6,193
    5,891
    Columbia, SC
    Ahh, yes. The confusion between an oil/filter service interval and the need to maintain/check per owners manual. But, I digress, maybe I'm the one who misunderstands. Apparently, a 10k interval for oil/filter changes actually means 'you never have to look at it' between changes, even though Toyota specs of "1 quart burning per 600 miles is within spec" is fairly common knowledge. You win.
    #20 TMR-JWAP, Apr 14, 2017
    telmo744, Patrick Wong and fuzzy1 like this.
