My Prius is Magic!
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by MIkeDr, Sep 3, 2022.
  1. MIkeDr
    MIkeDr Active Member
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    The last time I went to the dealer for service, my tread depth was 8/32 all around, with brake linings of 9mm at the front and 8mm at the rear.
    Six months later, I went to the dealer again. Now my breadth depth has increased to 9/32 in the front, and the brake linings increased to 11mm in the front and 9mm in the rear.
    If I keep the car long enough, the break lining and/or tread depth may become so thick as to become problematic. But right now, I'm please that it appears I'll never have to replace my brakes or tires.
    </sarcasm>
    Pulse07 and bisco like this.
    49,507
    LOL, the real magic is 'dealer service' those oxy-morons :p
    dacoobob, Pulse07 and alanclarkeau like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,513
    14,118
    Tampa, FL
    I can take three readings with a tread depth gauge in as nearly the same spot as possible and get three different readings. Also, the depth in the middle will probably be a little different from the edges and the edges from each other. So where the tech measures will also have an effect.
    fuzzy1, alanclarkeau and Doug McC like this.
  4. Mendel Leisk
    38,736
    Stretches credulity:
    Fronts, when new:
    Rears, when new:
    fuzzy1, jerrymildred and alanclarkeau like this.
  5. MIkeDr
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    Not if your Prius is Magic!
    Mendel Leisk and bisco like this.
  6. MIkeDr
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    Non sarcastically, I just thought it was funny.
    I’ll give the dealer credit. This was my last free ToyotaCare service. We put on 600 miles since the prior service, 6 months ago. I asked the service rep how often I should now be coming in. “Frankly, if you’re driving that few miles, just come in once a year and you’ll be good.”
    which is what I was thinking.
  7. Doug McC
    Doug McC Senior Member
    1,004
    377
    Midwest
    2022 Prius
    But jerrymildred you live in the real world (not just the Priuschat world). ;)
    jerrymildred likes this.
  8. ChapmanF
    15,664
    I measure my pads and micrometer my rotors at every tire rotation. I take every measurement myself, using the same instruments, consistently.
    And even I have occasionally written down figures that show a rotor "growing" (on the order of microns) between one tire rotation and the next.
    Clearly, I'm just not controlling perfectly for everything, like the exact spot on the rotor where I measure, and the temperature of the rotor and the tool.
    Throw in different technicians measuring at different times and different positions using different tools, and even more magic happens. :)
    Doug McC and jerrymildred like this.
  9. Mendel Leisk
    38,736
    For pad depth I use a tread depth tool, works well.
  10. jerrymildred
    11,513
    14,118
    Tampa, FL
    How much precision is really needed with brake pads? It doesn't take much more than an eyeball check to tell you if one set is wearing faster than the others. Precise measurements with dial calipers or micrometers just tend to generate worry. A ruler with mm markings is more than good enough for me.
    Mendel Leisk, BiomedO1 and Doug McC like this.
  11. ttou68
    ttou68 Active Member
    348
    205
    Well, the key factor is the minimum pad thickness...
    As long as not down to 1mm, it's safe to say you have plenty of pads left! LOL
  12. BiomedO1
    BiomedO1 Senior Member
    1,481
    801
    SacTown, Ca
    Jerry; you can still see millimeter marking on a ruler??? LoL I gotta grab the magnifying glasses nowadays.. LoL
    I just eyeball them, though I do admit - I haven't replaced pads in over a decade. The car either gets wrecked or sold; before I get to do brakes. I did the front wheel bearing assembly replacement on my GMC truck last weekend and blew the dust off my caliber compression kit. The pads was only 50% worn.
  13. ChapmanF
    15,664
    It's also usable to generate plots. :) Plot the thickness numbers against miles, project that out to where it intersects the minimum, and say "I budget for a new set of pads at around that mileage."
    Still necessary to keep checking, because some issue could have developed causing something to wear faster, but it's a fun exercise to see roughly what and when one is budgeting for.
    jerrymildred, fuzzy1 and Mendel Leisk like this.
  14. Mendel Leisk
    38,736
    Yeah, a bit past 90K kms, both the fronts and rears are down to around 6 mm remaining, on our. At that rate of wear, and considering they were all about 10 when new, they'll be down to 2 mm by 180K kms, if we ever get there.
    My "comfort level" is around 3 mm remaining, regardless of the 1 mm minimum spec: I'd replace if I'd gone to the bother of removing and saw that. Bit of a walk but not that far, to our dealership.
  15. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    You didn't actually expect quality work for something that was offered for free, right? That's why I'm always highly skeptical of their FREE X-point inspections.
    MIkeDr likes this.
  16. Mendel Leisk
    38,736
    For gauging pad thickness this is the go-to:
    You can whittle yourself a set, from some old popsicle sticks. So far I've done one:
    Finished the set, 3 should be enuf. Note that even 4mm is getting pretty puny, for brake pads:
    #16 Mendel Leisk, Sep 4, 2022
  17. MIkeDr
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    This was part of my last free scheduled ToyotaCare service. Judging by how much they billed Toyota, it looks like the standard 5,000 mile service (oil change and tire rotation) is around $100.
  18. Doug McC
    1,004
    377
    Midwest
    2022 Prius
    Sure. That “free” service didn’t cost you anything. Neither did the tires either, right? ;)
  19. Doug McC
    1,004
    377
    Midwest
    2022 Prius
    You realize that wood popsicle sticks absorb moisture and swell, right? :), WAIT!! I forgot this is the Prius Chat universe, (sorry about that).
  20. Mendel Leisk
    38,736
    Do you realize how trivial that is, with brake pad thickness. I was a draftsman (and checker) for a lotta years, and degrees of accuracy is always something to keep in mind. Say concrete placement, structural steel, machine shop: all have difference tolerances.
    I've got a dial indicator, a micrometer, a caliper (measured the wood bits with the latter), steel mm ruler, but round mm's is more than close enuf for brake pad thickness. Notice I don't even bother with odd mm's? 4, 6 and 8 is close enuf.
    dacoobob and jerrymildred like this.
