My Prius Making Noise While Engine Starts
Discussion in 'Prius v Technical Discussion' started by Wahid D, Oct 26, 2017.
  1. Wahid D
    Wahid D Junior Member
    Lahore
    Hi Guys I Have Prius S Led 2012
    Please Help :(
    When i start my prius engine its making noise in right side of the engine near to gear box, yesterday i go to toyota's service center but they said gear box is ok, actually they couldn't understand from where this noise start, please listen this noise and tell me why and from where my prius making this noise :(
    Marie15 likes this.
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Sounds like something vibrating at engine speed, bumping into subframe or some other structure. If the bumping sound goes away as the engine heats up it is almost surely exhaust system related. A perished isolator/mount, perhaps.
    Wahid D likes this.
    49,492
    how many miles/km on her?
    Wahid D likes this.
  4. Wahid D
    Lahore
    may be this noise is in parking motor?
  5. Wahid D
    Lahore
    its above than 90k
  6. Wahid D
    Lahore
    the sound is, like something is cracking
  7. Wahid D
    Lahore
    when i start engine then its making noise, im not confirm its making noise on drive because when i drive i didn't feel any noise
  8. bisco
    49,492
    difficult one. agree with airboss, maybe a loose or broken motor mount, or exhaust mount.
    Wahid D likes this.
  9. Air_Boss
    3,952
    1,083
    New Yawk
    Check the exhaust pipe heat shield to see if it is loose.
    Raytheeagle and Wahid D like this.
  10. Wahid D
    Lahore
    Thank You Guys, I'll check it today :)
  11. Ronald Jenkins
    Ronald Jenkins New Member
    Rockwall Texas
    When I start my Prius, I am getting aloud noise. Once it warm up the noise goes away. Has anyone else had this problem. And If so , What do you think the problem may be
  12. Air_Boss
    3,952
    1,083
    New Yawk
    A loud noise... from/located where? Continuing until ICE has finished warming cycle, or time-dependent, or distance-dependent?
