My Prius not pass smog monitor not ready
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by luiz oliveira, Sep 27, 2017.
  1. luiz oliveira
    luiz oliveira New Member
    richmond
    I have a Prius 2004 I buy very cheap with engine lights on, ok I fix the errors brake actuator , ok turn off the engine light, but I need pass I'm smog and not pass because monitor is not ready (oxygen sensor, evaporation system and catalyst) he say for me only drive the car , but I drive the car more than 5k and not ready..... somebody can help me? Thanks
  2. JC91006
    16,470
    8,383
    Do you have a problem with the 12v battery dying on you?
  3. luiz oliveira
    richmond
    do not . what happened and that sometimes when I turn off the car he dies. so I move on the battery cable and it works again, I already tightened the cables and now stopped doing it however I'm driving more than 5k miles and no monitor ready
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    The emissions system not ready to test is a separate item of it's own.
    The only way that driving will fix that is:
    If that is the ONLY error code shown.
    If other codes are showing up too, you must fix them first.
  5. JC91006
    16,470
    8,383
    Every time your 12v drains and dies, it will reset your car. That means all the driving you did goes away. So you have to make sure the 12v battery doesn't die again. Or you'll go in circles and never have the car ready for testing.
    jzchen and valde3 like this.
  6. luiz oliveira
    richmond
    I don't have engine lights on or codes . How to test my aux battery? Maybe can be a problem in my ECU?
  7. Sam Spade
    2,036
    1,023
    2017 Prius c
    Is this Richmond, Virginia ?
    I didn't think they had mandatory emissions testing.
  8. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    If it loses power and then gets it back by moving battery cable there has to be a bad connection there. And like JC91006 say as long as you keep losing power it will never go through monitors.
    So just fix the cable/connection and it should go through the monitors (or you get a fault code).
  9. luiz oliveira
    richmond
    I drove for 1k miles after fix the battery cables and not ready...
  10. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Then you obviously didn't fix it.
    Read the techstream data and it will tell you the miles and time driven since the codes were last cleared. This includes 12v battery drops. if those numbers reflect your 5k-6k miles driven, then your problem is elsewhere.
    I suspect everyone else is correct. You have a bad 12v aux bus something. Either the battery itself is dead, or as you say the cable is loose. The fact that it is loose suggests to me it has been messed with. It also says that it hasn't been charging very often so it could be near dead. Replace it and do the job properly. If you keep skipping steps, you are just wasting time.
  11. luiz oliveira
    richmond
    Ok I'm try fix
  12. Sam Spade
    2,036
    1,023
    2017 Prius c
    Do you REALLY have mandatory testing ??
    If not and it runs good, don't worry about it.
  13. luiz oliveira
    richmond
    Yes I live in Richmond California , my car don't passed because monitor is not ready
  14. Clix323
    Clix323 Junior Member
    Los angeles
    Did you fix it? I drove my more then 150 miles and its still.not ready
  15. JC91006
    16,470
    8,383
    You have to have mixed driving, not drive 150 miles highway speeds. I actually don't think all the systems have to be ready. Smog checks on the Prius is easy, as long as there are no lights on the dash, most places will pass it.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    When I smithed our 2010 several years ago, I did the egr circuit and disconnected the 13 volt battery. Then went to the smog shop which was about 45 miles away.
    The only system that didn't reset was the evap system, and that was fine.
    Might it be something else?
    Good luck and keep us posted(y).
    JC91006 likes this.
