My Prius Plug In Charges only 2.7 Kwh
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Goks, Jul 30, 2014.
  1. Goks
    Goks Junior Member
    Hello,
    I have a 2013 Prius Plug - The car is not charging fully i.e. 3.2 KWHs was many claim and have written in several forums and blogs. It has consistently been charging only unto 2.7 KWHs. I bought this last summer and its been more than a year and have seen all the four seasons. Obviously the number of miles it can run with a full charge varies depending on weather and all that. But I am not able to understand why it is not charging beyond 2.7 kwhs. I had asked this question to the dealers during the services but they don't have an answer besides saying that the 'battery seems to be good'. Any thoughts?
  2. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    That's quite normal. I've been seeing an average of 2.75 from the ChargePoint app.
  3. mrbigh
    3,686
    699
    Long Island, NY
    It is a normal re-charging capacity with the EVSE.
    51,154
    3.2 is max capacity, but the software limits it to 2.7 for max battery life, you're all good!(y)
  5. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    I've been keeping a record of estimated battery capacity based on SOC change, Charge kWh and an assumed charging efficiency of 90%. As you can see from the chart it shows a decline in amount of energy to charge and a decline apparent battery capacity. I'm not sure why there is variability in the data, perhaps the actual battery charging efficiency varies with temperature.
    #5 CaliforniaBear, Jul 31, 2014
  6. CaliforniaBear
    1,179
    289
    Northern California
    Maximum SOC 85%, approximate Minimum SOC 20% (3 bars), Battery specification 4.4 kWh full capacity
    (.85 - .20) * 4.4 = 2.86 kWh available capacity.
  7. bisco
    51,154
    thank you.(y)
  8. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    I wonder if some of the confusion is the built-in charger capacity (3.3kW/h) vs. actual charging energy used (2.8'ish kWh)?
  9. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    I think you have an extra "/h".
    The charger is 3.3 kW (although I see 1.9 kW with 240v in the car or 2.3 kW on Chargepoint Usage).
    The total capacity (not usable) is 4.4 kWh.
    The average amount charged seems to go up to 2.8-3.0 kWh, plus charging losses (about 10-15% I believe).
  10. Goks
    Goks Junior Member
    Hello Everyone. Thank you so much for taking the time to clarify on my question. I think all this information has given me more clarity.
    It is really sad that the Toyota dealers and the technicians there are not able to give this kind of information.
