My reverse camera stop working after I shortcut to wire by my mistake.
Discussion in 'Prius c Audio and Electronics' started by Peter Ros, Sep 24, 2018.
  1. Peter Ros
    Peter Ros New Member
    New South Welts
    ----Australia----
    Hi. I have toyota prius c 2018. I wanted to change the stereo. So I chop the socket (24*2 pin, that hase 4 color which are white, blue, red and black) and tried to connect the wire to new socket. By my mistake 2 of those wires made a shortcut and it had a smal flash. After that my reverse camera stop working even I use the original stereo and i change the socket.
    When I put the gear in reverse, there is nothing show in stereo. Is anybody knows what should I do? Thanks
    51,937
    welcome!
    have you checked the fuse?
  3. Peter Ros
    New South Welts
    ----Australia----
    Yes. It was a fuse named acc and it was 5a. I changed it after spark. Everything is ok now but the reverse camera. I did check all other fuse in glove box and engine.
    51,937
    maybe the fuse wasn't quick enough and something got damaged
  5. Peter Ros
    New South Welts
    ----Australia----
    Thanks for help. There is no fuse for reverse camera for toyota prius c 2018. Reverse camera connect to stereo straight. I made my own socket and its work nice now. Thanks. By away if someone needs a connection buy from toyota company. Its 15A$
  6. bisco
    51,937
    congrats, well done!(y)
    Peter Ros likes this.
