My setup (Torque with Mountek)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by usbseawolf2000, Jan 2, 2013.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I am quite happy with this setup. The only negative is the tightening knot blocking the Entune touch screen.
    Well, it is partially blocking the air vent but it doesn't bother me.
    F8L and raimix like this.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    51,141
    is that in the cd player?
  4. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Nice setup.. so that mount sits in the CD slot?
    I just have my G1 sitting in the front cup holder when I have it with me.
  5. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yes, it is a CD/DVD slot mount. Model is MT5000 if you want to Google it.
  6. raimix
    raimix Member
    204
    33
    Long Island NY
    looks good : )
  7. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I have that same mount, but I am not too happy that the top of the CD slot is so close to the edge. The CD slot bezel starts bending the second you try to tighten this mount. Same mount works great in my RAV4 tho.
    Thinking about putting a piece of plastic in the groove above the CD slot to provide some resistance, as I don't want it to be permanently bent/warped (leased car).
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yea, I noticed the same too but I am not too concern.
    I think it would be a smarter design if the tightening screw is on top (behind the phone) instead of at the bottom blocking the LCD.
  9. mrbigh
    3,686
    699
    Long Island, NY
    How about flipping the mount? I do not see why not
  10. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Then the phone would block the Entune screen.
  11. Electric Charge
    545
    133
    Syracuse, NY
    I plan on replacing that thumb screw with a regular short bolt, which should fix that issue (think the review on amazon had a picture of such a setup).
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Thanks for the heads up.
    BTW, Meritline is having this mount on sale for $17.50 with free shipping with coupon code: MLCKWM04
  13. Electric Charge
    545
    133
    Syracuse, NY
    Bummer, I tried getting one for my other car, but looks like this is the same coupon they used last time (several weeks ago, different amount), so I can't reorder it.
  14. Electric Charge
    545
    133
    Syracuse, NY
    BTW, what BT adapter are you using? Do you leave it plugged in? Thinking about trying to find a smaller one, as mine sticks out, and am concerned about accidentally kicking it.
  15. Johnny C
    Johnny C Member
    162
    16
    Boston
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I have Kiwi Bluetooth and I leave it connected.
  17. Jumpjet
    Jumpjet Member
    77
    25
    Here is how I have mine mounted.
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Very interesting. Instead of using the CD slot, slide it in the crack between the steering wheel and the dash. Very slick. Gotta try it!
  19. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I couldn't mount it like I thought you did. How did you mount it?
  20. Jumpjet
    Jumpjet Member
    77
    25
    I picked up a cellphone mount from Walmart, grabbed some 3m doublesided tape, I didn't trust the one that came with it because I didn't want any residue left behind. I stuck in on the steering column and it's been great ever since. BTW, I picked up a cheap pay as you go android cellphone from Radio Shack so that I have have Torque dedicated to it. Turned out a lot cheaper than a scanguage. Easily slides in and out of the holder. So it's set to turn on and off with the car so I never have to touch it.
    usbseawolf2000 likes this.
