My Toyota 2010 12 v Battery charge is draining
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by alexk345, Oct 31, 2023.
  1. alexk345
    alexk345 Junior Member
    40
    india
    hi all experts,
    I have prius 2010 but my car sitting idle. So i bought trickle down charger and charged it full. So i removed it last night after it showed full
    Then today i connected trickle charger again and its charging for more 45min now and still not full.
    Not used it after last night charging.
    Why it lose battery charge on its own. Can someone tell me how to maintain battery? Is there battery liquid?
    How do i check its low?
    Let me know.
    thanks
    alexk
  2. JC91006
    16,482
    8,400
    Battery is too old, low capacity. Trickle charger are not used to charge, but to maintain
  3. Doug McC
    Doug McC Senior Member
    1,004
    377
    Midwest
    2022 Prius
    is it a Gen 4 or Gen 3? Gen 4 have lead acid batteries that you can add water to, while Gen 3 have AGM which you can’t add water to. Additionally, if you’re trying to charge an AGM with the charger set for lead acid (or vice versa) you will have problems. Plus a trickle charger will EVENTUALLY bring the battery to a full charge IF it is charging at a rate higher than the parasitic draw (which most are capable of).
    49,489
    how old is the battery?
