My transaxle cover was backwards. Potential serious problem!
Discussion in 'Gen 2 Prius Main Forum' started by mcbrunnhilde, Sep 4, 2006.
  1. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    I'd like to send a GREAT BIG THANK YOU to hobbit for the information he posted about the backwards transaxle assembly cover that could potentially damage the M/G wiring harness (I hope it's OK to post your link here...).
    http://techno-fandom.org/~hobbit/cars/starthole/
    When I took my car in for the steering recall, I asked them to take a look at it, and they told me mine was done incorrectly!! Since my sister in Virginia got her Prius on the same day I did, I e-mailed her the link so she could have her dealer there take a look at it--and HERS was wrong as well!!!!!!!!! We're both very grateful that ours got corrected before any problems came of it--and our respective dealerships are now alerted to this problem. I don't know if they'll check every car that comes in since there's no TSB or SSC about it at this time, but I hope they do.
    According to hobbit's link, I guess this only affects 2004 and 2005 (?) cars, and I encourage others to take this info to their dealers to see if they have this problem as well and get it corrected.
    BTW I bought my car on 3/29/04, my build date was 2/04, and my VIN is 51xxx. I don't know my sister's VIN, but I imagine it's very close to mine.
  2. Solar_Powered
    Solar_Powered New Member
    38
    Cypress, Southern California
    After reading your post, I drove the front tires of my Prius up on some 2x4 scraps so I could squeeze underneath and take a look. Sure enough, my 2005 has the cover "tab" very close to the wiring harness as you described. But in mine, it was not touching (about 1/32" gap). The harness itself is encased in the hard black plastic wire loom, and I would guess even if it was touching, it would take a lot of vibration to penetrate.
    But being on the safe side, I cut a 1" piece of scrap heater hose, split it, and slipped it over the wiring harness for added protection.
    Thanks for the post.
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    The problem is still present in the '06 models.
    I'm told it has been responsible for the early demise of at least
    one Prius fresh off the boat, but it could very well be that the
    likelihood of an actual problem is still fairly low in most of them.
    Still, if Toyota recalls cars because a Sumo wrestler can deliberately
    jam the wheels up against a curb and twist the crap out of the steering
    shaft, they can certainly recall cars for something like this too.
    _H*
  4. mcbrunnhilde
    619
    26
    <div class='quotetop'>QUOTE(hobbit @ Sep 4 2006, 08:53 PM) [snapback]314361[/snapback]</div>
    I wonder if it would help if a lot of Priuschatters went to their dealers with your pictures in hand. If dealerships started calling Toyota corporate saying that they were having to correct this, maybe we'd get a TSB out of it at the very least. Toyota has had to recall a lot of cars in the last year or so, and I can understand their reluctance to issue one when there's such a small failure rate. Didn't we get a gas tank TSB because of all the owner complaints? Let's go for it with the transaxle cover!!! :)
  5. daronspicher
    daronspicher Active Member
    1,208
    what are the rules on getting electrocuted when looking for this problem? If it's in stage 4 of wearing out, you die for touching the transmission as you inspect?
    As long as the car is "off", the wiring contains no live current?
    Every so often Ford or Chevy would build a new car with the radiator hose rubbing on something like this.
  6. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(daronspicher @ Sep 5 2006, 04:49 AM) [snapback]314438[/snapback]</div>
    I doubt you'd get electrocuted on something like this... when the car's off, the HV battery is disconnected, so there's no worry there. In addition, the 12V battery just doesn't pack enough of a punch to do serious damage... sure, your fingers or hand might tingle for a little bit if you accidentally touch some live wires, but there'd be no lasting damage.
  7. richard schumacher
    7,664
    1,043
    United States
    The wiring harness which is at risk when this cover is installed backwards never carries high voltage. It is not dangerous to handle. All of the high voltage harnesses are bright orange, and they are live only when the car is on.
  8. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    I made a similar post at the Care, Maintenance and Troubleshooting forum, http://priuschat.com/Possible-harness-dama...ius-t23870.html. Great that your dealer actually correct the problem for you. The dealer I went to didn't want to do any correction without Toyota's instructions. I haven't have time to call them back. Maybe I'll do it today.
