My Trunk Door -- Is this Right?
Discussion in 'Prius v Main Forum' started by jimlie, Feb 6, 2014.
  1. jimlie
    jimlie New Member
    2014 Prius v wagon
    Hello PriusChat - I am new owner a Prius v - 3 Package. :)
    Can you folks please help me out?
    If my doors are all locked and I walk up to the trunk with my key fob in my pocket, how do I open the trunk? Can I:
    a) Pull open the trunk handle and it automatically unlocks ?
    OR
    b) Do I have to use the key fob and press the unlock button twice to unlock all doors, then I can press the button to release?
    thanks!
  2. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    If it's anything like my Prius hatchback 3, then you can use method b. Or you can program your SKS to unlock all doors when you grab the driver's door handle. Then you can walk to the hatch and open it.
    SCH-I535
  3. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    On the v Five with SKS set to open all doors at once, with the fob in hand, touching the trunk opening button unlocks the trunk and other doors.
  4. jimlie
    jimlie New Member
    2014 Prius v wagon
    got it // so only the prius v - 5 package. thanks folks!
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,983
    4,726
    Texas Hill Country
    Yes, as indicated above the 3 can be opened with the keyfob or, if configured, by touching the drivers door. Annoying but I usually walk to the drivers door, touch it, and then go to the trunk.
    Procedure: With the car off, Press and Hold "Lock" and "Unlock" keyfob for 5 seconds to change the keyfree mode
    #5 rjparker, Feb 6, 2014
  6. Dirtnapper
    Dirtnapper Member
    104
    MA
    2014 Prius v wagon
    I just picked up the Prius v Three (lowercase v, and three not III) on Tuesday, and for whatever reason when looking at the vehicle I did not notice this missing feature; I had it on the Gen II Prius and nowI miss it.
  7. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    Yep, a really annoying omission by Toyota.
  8. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    The fob can be programed to unlock all doors on the first press.
    The driver's door can be programmed to unlock all doors when touched.
    Sadly there is no way to get 3 door SKS on the v without softtex.
  9. mikefocke
    3,701
    1,649
    Sanford, NC
    I reach into my pocket and press the doors open button on the fob twice and my rear is unlocked by the time I get to it. It has become instinctive as my hand now knows the shape of the fob and where the door open button is on the fob. (v3)
  10. rjparker
    7,983
    4,726
    Texas Hill Country
    Hey don't give away all the secrets...
