my wheel won't come off the car
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Lucas Reinhart, Mar 1, 2017.
  1. Lucas Reinhart
    Lucas Reinhart New Member
    Clinton, IA
    I had the same issue last night while I was changing the brake pads on my 2010 Prius on the front. on the front passenger side I had used a hammer with something to protect the wheel took me about 45 minutes to get the wheel off. by the time I was done with that wheel I had a light bulb moment. Whenever I change the brake pads on a car I always go down to AutoZone or O'Reilly and I rent the master brake set. Master brake set comes with a variety of tools including a vice with a plate that's shaped like a brake pad but it's just a thin piece of metal. so I use that pry vice and stuck the plate between the back side of the rim and the other end of the vice on the rotor and I just cranked it and tell it popped off took about three minutes to get that tire off. so owning one of these pray vices might be a good thing to keep in the car specially if you have to change the tire on the side of the road, cost about $8 to get just the pry vice. You can get the whole set for about $55 at advance auto parts.
  2. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    A sledge to the back side on the rubber, rotate and hit again, anti seize compound on one of the mating surfaces will prevent future mishaps.
    stormchaser likes this.
  3. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,136
    1,581
    Iowa
    My tires are due for rotation this week, but it won't be happening soon, as I am still recovering from injuries sustained from a January ice storm.
    I have not had any problems since I wire brushed the wheels and put on anti-seize compound. But, never pays to be too sure....
    Hopefully, I will get this done in a couple of weeks.I just loosen the lugs and drive it back and forth a bit. Works fine without hammering on a tire that is up on an insecure jack.
    kris
    #3 cyberpriusII, Mar 1, 2017
    Tande likes this.
  4. Mendel Leisk
    38,726
    If you're raising the car on a smooth concrete slab, this might work for you, it has for me:
    Half-loosen lug nuts (just so the tension is broken, but they're still wrench-tight)
    Raise car and put in safety stands, aiming to have minimum clearance between tire and slab, say 1" max.
    Remove all lug nuts and try pulling off wheel. If it's no-go:
    Reinstall one lug nut, nearest top of pattern, very loosely, just a few turns on
    Place a 4x4 timber block against the inside face of tire (two 2x4's will do in pinch, what I actually use)
    Take your largest sledge hammer, lay it on the flat on the slab, at about the middle of the car, adjacent to the stuck wheel
    Swing the sledge hammer into the 4x4 timber
    If at first you don't succeed, try a little harder...
  5. Boffin
    Boffin Member
    43
    65
    Maryland
    Once you get it off, Lucifer's suggestion about anti size will mean you never have this misery again. My wheels too, when I first removed them, took 2x4s and drilling hammer persuasion. After anti seizing them, no problem!
  6. Danger
    Danger Member
    175
    22
    Frisco
    What anti seize are you guys using on the back of the wheels?
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Permatex is what I've got, though it's super old. A little goes a long way, so it lasts forever.
  8. Mendel Leisk
    38,726
    Steel rims don't seem to glue on like this. I suspect it's aluminum rims on steel hubs that are the problem. And as the inside face of the aluminum rim corrodes it maybe gets a skin that reduces the gluing?
    I try to avoid anti-seize, since I wash the rims when they're off the car, and I don't much like seeing a sheen running down the street to the storm drain. My sledge hammer method is the the naz, works every time. :)
  9. cyberpriusII
    1,136
    1,581
    Iowa
    Permatex. I have no sheen, but then I never wash the car.....Oregon weather does it for me.
  10. ChapmanF
    15,614
    With a regular-enough rotation schedule, mine don't seem to ever get all that bad. I like it that way, because should I ever want one off at the side of the road, I might not have a sledge handy.
    When it gets a bit stubborn, something like a plier handle through the wheel to pry against the caliper bracket (the nonmovable part) seems to do the trick, with even less force than I expect. (I surprised myself once by succeeding with only my thumbs through the wheel against the caliper bracket; this after no success at all trying to just pull the wheel off, worrying I'd shake the whole car off the jackstand.)
    -Chap
  11. Mendel Leisk
    38,726
    Good point, about roadside wheel removal. Maybe I'll put a sparing app of anti seize. As in put a dab and then wipe it off, rely on there being some residue. I'll be swapping out the snows for OEM wheels in a week or two.
  12. cyberpriusII
    1,136
    1,581
    Iowa
    With the anti-seize, I have not had a problem removing for flats or rotations for several years. I guess, if I were wanting to do worse case planning...but seriously, since the wire brush treatment/anti-seize, it is easy-peasy.
  13. Mendel Leisk
    38,726
    This is our daughter's Pilot, three out of four rims were glued on. I'll post a pic of my techonique. I applied a thin patina of anti-seize at the hub, and brushed it outwards too. Did the same thing on our Prius, when taking the snows of a couple days back. So, belts and braces. Anyway, a pic of what I do when they're stuck:
    (Leave one lug nut on, very loose, at the top of the pattern. To prevent the wheel flying off or rolling away.)
    #13 Mendel Leisk, Mar 17, 2017
    Raytheeagle likes this.
  14. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    Thanks, Mendel. Note the solid jackstand, folks! (y)
  15. Mendel Leisk
    38,726
    Good point. This is really an in the garage activity, car on safety stands, place on solid bearing points. Either the front or rear, or the whole car. Also, the tire is best kept close to the slab, just clear.
  16. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    I wipe some high-temp disc brake grease on the hub lip after rubbing off all the rust with coarse scotchbrite sanding pad. I also wipe some of the same grease on the wheel where it contacts the hub. This grease will not wash out, and my tires come off easily.
  17. Mendel Leisk
    38,726
    I'd be inclined to stick to a thin coat of anti-seize, more concentrated around the hub. The further out and more liquid the grease, the greater the likelihood of centrifugal forces migrating it to the discs?
    #17 Mendel Leisk, Mar 24, 2017
