my yellow metal ramps don't work on my prius???
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Oct 11, 2010.
  1. ski.dive
    ski.dive Active Member
    963
    242
    Hutchinson Island,FL. Mt. Snow,VT
    I tried to use my yellow metal ramps to raise my prius, but the bottom of the front bumper would hit.
    what can i do to modify it so the bottom of the car will not hit?
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yellow metal ramps? I am guessing something like:
    ______\\
    that you drive onto? If so, then get ramps with a longer angled section so the height variance isn't as great.
  3. Jon the Chief
    Jon the Chief Jon the Chief
    50
    Wolverhampton UK
    Keep the same ramps, just use a pair of wood planks to extend them and give a shallow angle
  4. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    +1, decrease the angle of rise,
    planks, or shim the front, or go to pep boys and by some cheap shallower ramps ... mine work for my Prius and my truck, but truth be told, it's no easy feat getting a floor jack under the Prius either
  5. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    Mine aren't yellow but the same concept. I put 2x4 pieces in front of the ramp and it's just enough to raise it up and miss the bumper. Drive the car onto the 2x4 which raises the car up then onto the ramp. I had to do this with my mustang also. BTW, same concept - you can't rent a tow dolly from any rental place because the prius is too low to put on the dolly.
  6. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    My floor jack works just fine, no problem at all, unless you have a huge commercial one. I use it every 5000 to rotate my tires. The ramp, however is a pain....
  7. ursle
    ursle Gas miser
    1,049
    192
    NH
    My yellow metal ramps came with plastic pieces that snap into position to walk the car up the ramps gradually, if using wood secure the wood in place, it would get ugly fast if they slipped and the vehicle err, gomered.
  8. ski.dive
    963
    242
    question:
    the 2x4 goes on the low side of the ramp, correct?
  9. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Put them in front of the ramps, up against it. I used a 2x6 and a 2x4 just to make sure I had enough room to get the tires on the wood before the bumper hit the ramps. I have the smaller Rhino ramps, also.
    It works great for oil changes, just enough clearance to open the splash guard cover and have the ground keep it open and not flopping around.
  10. ski.dive
    963
    242
    ***so the 2x4 goes in front of the ramp, not under the front of the ramp, correct?
  11. wick1ert
    1,311
    183
    Delawhere
    Correct.
    If 1 - 2x4 doesn't turn out to be enough, put another one in front of the first.
  12. donalmilligan089
    239
    22
    virginia usa
    I had the problem with u-haul dollies. They were not too high but not wide enough. I FOUND AN OLD MODEL (81 INCHES ) between fenders. It has a 2 foot ramp that lowers to load and raises to haul. Many have offered to buy it but I rent it and keep it for my friends. I believe the black plastic ranps at Advance Auto would do better Don
