Mysterious components
Discussion in 'Gen 2 Prius Audio and Electronics' started by 04 Prius, Oct 6, 2019.
  1. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Hey all,
    I helped out a friend yesterday with the infamous no dash display combined with car not shutting off properly issue. We swapped out his instrumentation assembly with a known good one, and now I’m analyzing his old part to see if I can locate the issue.(it wasn’t that little 100uf capacitor).
    My question today is, as I remove all the plastic covers on the assembly, I encountered 2 tiny circuit boards that are on the small cable that plugs into the right end of the main display board, they are in small plastic T shaped housings with a small black plastic cap. They are some sort of sensor boards, the stem of the T comtains a small steel pellet that can rattle in the housing, there is a sensor on the board that monitors it. When the assembly is in correct position, the pellet rests against the sensor. Does anybody know what these are for? My first guess is some sort of rollover sensors, but they only plug into the display board with plain connectors (not yellow).
  2. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    A picture might help?
  3. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    The cluster is upside down in my bench in these pictures, the circuit boards would normally be on bottom.
    666377D8-6864-4207-90F3-A9F86080A180.jpeg 17E663CD-A046-4670-8476-EA972028BCBB.jpeg
  4. ChapmanF
    15,456
    Sounds like you're talking about the inclinometers, which allow correcting the fuel gauge for whatever slope the car is on. There should also be a procedure in the Repair Manual for recalibrating them (I know there was, in Gen 1).
  5. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Interesting...... I would’ve never guessed that, yet it makes sense!
