Mysterious Dead 12v Battery
Discussion in 'Gen 2 Prius Main Forum' started by farmprius, Mar 14, 2023.
  1. farmprius
    farmprius New Member
    asheville nc
    Hey y'all, new to the forum.
    I've got a 2006 prius with 212785 miles. I had the hybrid battery replaced about 7 months ago. Car has been driving fine since, no apparent issues except it started revving unnecessarily while not accelerating in high gears lately, if that is relevant.
    Recently went on a 600+ mile road with no issues on the trip. Upon returning, the car sat in the driveway for two days. Got in and it wouldn't turn on, all electrical completely dead. I jumped it which brought the electrical to life while connected to the other car, but engine wouldn't start and car died immediately after disconnecting. Was able to use the OBD reader while jumping but there are no codes to report.
    I took the 12v battery out and tested it- completely dead. This 12v was brand new as of 7 months ago when I got the hybrid battery replaced. Any ideas what could cause the battery to drain like this?
    I did get into the throttle body and saw that needed cleaning so I am wondering if that could be the culprit... not totally clear how that correlates but worth mentioning. Waiting for the 12v to charge up now, wanted to pick your expertise while I wait.
    Thanks in advance for chiming in!
  2. Tombukt2
    Tombukt2 Senior Member
    13,481
    2,424
    Durham NC
    In my '08 car which is exactly like yours for the most part when I had a lot of slipping going on it was because my hybrid battery was just starting to fail 3 months later I had a lot more slipping and the battery was toast red triangle on correct p code etc. During this time all I had to do was step on the gas while the car was moving 45 mph smartly and the car would rev away just like a clutch would be slipping in a manual automobile I did this many times checking and playing around nothing was really wrong with the car other than the hybrid battery didn't have the get up and go that it used to and when you got on it like thinking you were going to pass a car or whatever and you weren't careful you would hear the engine revving away and the car going nowhere additionally. The minute the hybrid battery was changed leaving from the parking lot where I change the battery I could almost break traction just like that that had to be something to do with the failing hybrid battery The minute it was changed out the front end was put on the battery with the computers and relays and it was wired in and two bolts were in it Bam it was a different car immediately so I don't know if you got a new hybrid battery or a rebuilt remanufactured setup maybe you need to revisit that and see if there's any issues with connections growth and frosting of the nuts all of that sort of thing and some countries this can come on very quickly versus other places certainly I'd be looking at that almost immediately If in fact I had a rebuilt battery if I had a new battery from Toyota I would definitely be checking with them and seeing if I have any warranty or how that works
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,000
    NJ-USA
    Sounds like some type of high parasitic draw- something on the car uses "too much" current when everything's supposed to be off. A common fault is a map light left on, or the tailgate wasn't completely latched.
    If it happens again after fully charging the 12V, then you need to do some testing. Not many folk have a milliamp range inductive current probe. So I use a multimeter that has an internal amp shunt.
    First I configure the meter to read amps (use the 10A range). Then connect a test light or other small bulb to 12V through the meter- I want to see the light work and a good amp reading to be sure that the fuse inside the meter isn't blown.
    Now carefully disconnect the 12V negative clamp and "connect" the meter between the clamp and the battey terminal. Might need spring clamps, (careful use of) vice grips, etc to get solid connections.
    The tailgate warning and dome lights should be on. Use a screwdriver to fully "close" the t/g latch (don't forget to release it when done before slamming the t/g).
    Check the reading after 10-15 minutes. Should be 15-20 mA.
    Brian1954 likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Don't overlook the obvious.
    BRAND new and relatively new batteries sometimes fail.
    Try to charge it first.
    Does this "new" battery have a warranty ??
    Good advice in post #3 above too.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,874
    861
    Southern California
    Carabiner's work well for this too. I put something through the protruding loop so that I don't forget it's there and close the hatch on it. Pick one roughly the same size as the loop on the tailgate.
    The carabiner is also handy if you ever need to move something which is a little to big for the hatch to close. Stuff the carabiner into the latch and attach a rope between it and the loop on the hatch.
  6. bisco
    52,408
    get the battery fully charged, then load tested. if it passes, record the voltage and let it sit overnight. if it hasn't significantly dropped, reinstall it and do the same measuring overnight.
