Mysterious drain tube
Discussion in 'Gen 2 Prius Main Forum' started by sam jordan, Jul 30, 2023.
  1. sam jordan
    sam jordan Junior Member
    2003 Prius
    Does anyone know what this drain tube does?
    It's located on the right rear passenger side coming from behind the headliner and running down the C pillar, connecting to a tube that seams to run on the floor towards the dash, then goes back up into the fire wall.
    I'm installing a new OEM HV battery and noticed this line is full of water. I got some weed Wacker trimmer wire and tried to unclog it but ran an easy 10' of string down the tube before it stops. I cannot unclog it.
    A bit weird it doesn't drain at the bottom of the car?
  2. Mendel Leisk
    40,574
    Sunroof model?
  3. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    I believe what you have there is the rear window washer supply line.
  4. sam jordan
    2003 Prius
    No sunroof .
    Rear window washer makes sense. Good thing I drained it lol
    ColoradoCrow likes this.
